I have to measure a DC current with a non invasive method. I don't need a high resolution, just I need to have a range about 0-70A
Could you suggest me some sensor able to do that and with an easy plugin with Arduino (I'm not much expert in soldering or build integrated circuits!)
Ulixxes:
Unfortunatly in need to work with DC current..
I thought those clamp-on things worked by Oersted effect. If they don't, there is probably something that does. And why the need to be non-nvasive anyway?
There are 2 types of clamp meters.
The cheap and nasty ones are simply a current transformer and only work with AC.
The better ones that will measure both DC and AC have a calibrated Hall Sensor, but are also more expensive.
Thank you very much for the answer. I would a non invasive method just because the current to measure are of a device already cabled and I don't want cut connections to insert the sensor. I was hope that exist some cheap measure sensors but I seen that are always for AC..
