Measuring 2 voltages
I'm working on a solar powered project. I need to measure voltage on the battery and voltage coming from the solar panels.
I made two simple voltage dividers and they work great on either Battery or Solar Panel, but it gets real funny when I try to measure both at the same time. I think it has to do with a common ground. Has anyone managed to do this? Any ideas?
Thanks
Hi bikemind
You'll have to be a bit more specific than ...
:slight_smile:
But, at a guess, do the readings get better if you analogRead() one device twice and use the second of the two readings, and then do the same for the other device?
All the best
Ray
If this is a hardware question , what is the chance a schematic would help ?
(deleted)
Do you think that this might help? Gammon Forum : Electronics : Microprocessors : Using the Arduino Analog Comparator
Unless you post a schematic of your setup all we can do is guess and you wouldn't want that would you?
Schematic = answer
You got any code?
Any ideas?
Not without a schematic and code.
The solar panel's voltage will drop in relation to the current being drawn from it. If you have it connected to the battery then the voltage will appear to be nearly the same as the battery.
As an addendum, measuring the voltage from a solar panel when it's not connected to any load is referred to as the "open circuit" voltage. Measuring that might be helpful in finding out the panel's peak voltage but it has very little to do with the panel's power generating capability.
The Wikipedia article on Maximum Power Point Tracking (MPPT) is helpful in explaining this behavior.
Yes, we already gave you our ideas and we're waiting for you to do something
bikemind:
Funny "ha ha" or Funny "peculiar"?
no schematic, no code , no answer
11 replies and none from the OP.
Perhaps delay(48hrs); is needed?
...R
