Dear all,
I would like to measure four air speed sensors MPXV7002DP through the 16bit A/D convertor ADC1115 (more info here. Analog outputs from MPXV is connected to each channel of ADC and power supply is through breadboard from Arduino UNO. The problem is, if I connect only one sensor and in code I have reading of only one channel - it works. If I try to code reading from 4 channels it shows this reading
16:56:20.323 -> 98.36 ovf nan 0.00
Where the last reading is connected channel with sensor.
Can I kindly ask you, if you could give me direction what could be problem?
Wiring of the ADC to Arduino is showed on following link
The skectch of code is below.
#include <Wire.h>
#include <Adafruit_ADS1015.h>
Adafruit_ADS1115 ads_a(0x48);
float V_0 = 5.0; // supply voltage to the pressure sensor
float rho = 1.204; // density of air
int offset0, offset1, offset2, offset3 = 0;
int offset_size = 5;
int veloc_mean_size = 10;
int zero_span = 2;
ads_a.begin();
int16_t adc0, adc1, adc2, adc3;
adc0 = ads_a.readADC_SingleEnded(0);
for (int ii=0;ii<offset_size;ii++){
offset0 += ads_a.readADC_SingleEnded(0)-(32768/2);
offset0 /= offset_size;
adc1 = ads_a.readADC_SingleEnded(1);
offset1 += ads_a.readADC_SingleEnded(1)-(32768/2);
offset1 /= offset_size;
adc2 = ads_a.readADC_SingleEnded(2);
offset3 += ads_a.readADC_SingleEnded(2)-(32768/2);
offset2 /= offset_size;
adc3 = ads_a.readADC_SingleEnded(3);
offset3 += ads_a.readADC_SingleEnded(3)-(32768/2);
offset3 /= offset_size;
// average a few ADC readings for stability
for (int ii=0;ii<veloc_mean_size;ii++){
adc_avg0 += ads_a.readADC_SingleEnded(0)-offset0;
adc_avg0/=veloc_mean_size;
// make sure if the ADC reads below 512, then we equate it to a negative velocity
if (adc_avg0>16384-zero_span and adc_avg0<16384+zero_span){
} else{
if (adc_avg0<16384){
veloc0 = -sqrt((-10000.0*((adc_avg0/32768)-0.5))/rho);
} else{
veloc0 = sqrt((10000.0*((adc_avg0/32768)-0.5))/rho);
adc_avg1 += ads_a.readADC_SingleEnded(1)-offset1;
adc_avg1/=veloc_mean_size;
if (adc_avg1>16384-zero_span and adc_avg1<16384+zero_span){
} else{
if (adc_avg1<16384){
veloc1 = -sqrt((-10000.0*((adc_avg1/32768)-0.5))/rho);
} else{
veloc1 = sqrt((10000.0*((adc_avg1/32768)-0.5))/rho);
adc_avg2 += ads_a.readADC_SingleEnded(2)-offset2;
adc_avg2/=veloc_mean_size;
if (adc_avg2>16384-zero_span and adc_avg2<16384+zero_span){
} else{
if (adc_avg2<16384){
veloc2 = -sqrt((-10000.0*((adc_avg2/32768)-0.5))/rho);
} else{
veloc2 = sqrt((10000.0*((adc_avg2/32768)-0.5))/rho);
adc_avg3 += ads_a.readADC_SingleEnded(3)-offset3;
adc_avg3/=veloc_mean_size;
} else{
if (adc_avg3<16384){
veloc3 = -sqrt((-10000.0*((adc_avg3/32768)-0.5))/rho);
} else{
veloc0 = sqrt((10000.0*((adc_avg3/32768)-0.5))/rho);
Serial.print(veloc0,2); // print velocity
Serial.print("\t");
Serial.print(veloc1,2); // print velocity
Serial.print("\t");
Serial.print(veloc2,2); // print velocity*/
Serial.print("\t");
Serial.print(veloc3,2); // print velocity
delay(50); // delay for stability
