Robin2:
The usual rain gauge has an identified catchment area - usually a circle with sharp edge. The vessel beneath may have a smaller diameter or be conical so that the depth would be multiplied for easier reading. The vessel would be calibrated to allow for the effects of the shape. Hope that makes sense.
Any vessel with an identifiable entry surface area would do. It may be more accurate to weigh the water rather than measure its depth.
...R
I agree that weighing would be more accurate, but with a 50% discrepancy I am not too concerned about accuracy at the moment. Yes, that all makes sense, thanks.
jremington:
The description says it is a "tipping bucket" gauge. Usually this is implemented by a magnet and reed switch, so you get one pulse each time the bucket tips (according to the docs, for every 0.011 inch of rain).
If you can verify that no pulses are missed, then a fix would be to change the additive constant in the code to reflect reality. All sensors can benefit from calibration!
Given the small area of the capture opening on that system, I would expect droplets to adhere to the sizes and evaporate rapidly under conditions of light drizzle or intermittent showers, so the gauge would tend to underestimate the true rainfall.
I use a straight sided bucket with a ruler, and that agrees pretty well with the professional reports from the local airport . We are on a rainwater system for everything, so I have to keep track.
The document I have says 0.2794mm per pulse, which agrees with the 0.011 inch you have.
I have only checked this in a storm, like 10 to 20mm of rain in a few hours, I don't think light rain evaporating off the sides is the problem
(Although a wet cat coming in and leaving muddy paw-prints everywhere is another story :o )
Your bucket and ruler method seems to validate what I have tried, thanks.
The gauge is mounted on a pole on the end of the house (not the one shown in the documentation, it's too wobbly) with a D1 Mini in the loft to relay the data over Wi-Fi. I'm trying to avoid taking it down.
More investigation needed, thanks for suggestions.
