For the rain gauge my idea is to have a container which would capture the rain over a 24 hour period
then measure the amount in inches/cm and record. Once done empty the container and repeat.
Is this idea feasible or am I complicating what is already out there ?
There are two ways that I can think of off hand. Each with its Pros and Cons.
1- Plug a hole in the bottom of the tube with a rubber stopper that's connected to a spring loaded solenoid. When you apply power to the solinoid it will push the stopper up releasing the water and when the power is removed the spring will pull it closed.
Pros - Easy to build. Cons - Debris can get caught between the stopper and the tube causing a leak.
2- Make a tipping point about half way up and tip the tube over more than 90° to drain it and then rotate it back up vertically again after a few seconds.
Pros - Debris won't cause leaks. Cons - May be much more difficult to build.
My idea was to have a tube/Rain Gauge which had a bracket in the middle. This bracket is attached to a rod which is controlled by a small motor which rotates the rain gauge which empties it.
This would have to run once in a 24 hour period.
Anyone had any experience with an easy way of measuring water level?
Most professional rain gauges use a tipping-bucket mechanism (see Rain gauge - Wikipedia) so as to avoid having to empty anything. It also simplifies the design of your weather station since all you have to do is count the impulses.
For this project I am trying to keep the cost down of the unit.
I think I will be going with a Tube/Rain Gauge container which will be on a rod which
will turn and empty the container. This will be driving by a servo motor.
To measure the rain level is the challenge. I could use the e Tape but again it's to pricey.
What are the alternatives ?
Ultrasonic sensor
DIY Two electrodes and then calculate the amount of water.
It will be engaged once every 24 hours and then turned off.
I'm a card carrying member of the "doing yourself is more fun" club... and have MADE tipping bucket gauges... but have to say that maybe for THIS project the hardware has been done, and done well, and not too expensive, and that still leaves a lot of fun (time) to spend on the software.
Your approach illustrates an interesting dichotomy in all measuring... measure increments continually, or measure what collects in a given time period. With rain, it is really nice to have the greater resolution of "drops per minute". The blue line at...
... is rainfall. (Vertical gray bars: Midnights. 25 Feb, there was a brief but fairly intense rainstorm. If there'd been light drizzle for a while, you could have the same AMOUNT of rain, but the event would have been different... and the difference lost without a tipping bucket "answer".
I've seen the windspeed and wind direction sensors in the Maplin range, and they are very nicely done. If you've done no rainfall measuring, the one mentioned on previous posts makes a good starting point. The size of the opening at the top is a bit small.... USA NWS suggests 8" diameter, I believe. Be sure to mount where you can service regularly.
Keep the "servo tip"... the "see-saw" is hard to make work.
Put a big funnel above your collector, so a light rain gives you a lot of water to detect.
Use a "captive" float switch to tell the Arduino when your collector has collected a certain amount of water. Tip the collector then; track tippings per hour/ day/ etc.
Ok, I have made up my mind I am going to go with the servo motor for the tipping of the rain container.
For the rain level I am going to try two methods -
WATER / LIQUID SENSOR MODULE - I think this can be submerged in water?
As it is only 40mm, instead of taking a measurement every 24 hours I will
be taking a measure every hour and then totaling to get the rain fall for the 24 hour period.
Capacitive liquid level sensor - Will build and test both methods in the water and non contact
Will be doing the measuring once in 24 hour period.
This is going to be pretty chalanging as I am a real beginner to Arduino and coding.
Will have to do a lot of stealing of sketches and code, then getting the forum to steer me in the right direction.
I don't think that any National Weather service is using these little units... but for hobbyist fun, they are MORE than adequate. And anyway, always to EVERYTHING (outdoors) connected with weather sensing in a very maintainable way. Only two wires run to the sensor. And it will be the same if you replace it. Make it easy to change the sensor at the top of the pole if you decide to go for a "better" one... be it five days, weeks or months from now. In the meantime, you can start building the rest of your system... if you can find a US supplier! (Or the factory in China). The devices are NOT hard to mass produce. It is just the "one off" that is hard to make. A fancy one has better bearings... more consistent relationship between wind and readings... and stronger arms. (Birds sometimes land on the "windmill".) Sigh. But for $8, if a fat crow wrecks it, it's not the end of the world, is it?
For US source, I don't know if you saw the "ask them nicely" part at...
They'd be no trouble or expense to ship from the UK... very light. You must know someone? Try Facebook!... Or some of the small UK distributors... Hobbyboards.co.uk comes to mind as one that might help, if you ordered some of their Good Stuff.
Another no-moving-parts "is the water THIS high yet" sensor which MIGHT suit is the sort used in some inkjet tanks... it relys on clever use of the way refractive indices depend on the materials at the interface. Littl prism inside tank reflects an LED beam back to a sensor when awash with ink, doesn't when not (or vice versa).
