elvon_blunden:
Ok so if you got 4 pulses, you can't tell is it's 2x short 2-pulse strokes or 1x long 4-pulse stroke, hence the need to check the seat position?
Yes, essentially that's the problem!
elvon_blunden:
Won't there be a gap in the pulses while the rope rewinds, so 2x short strokes might be pulse-pulse, gap, pulse-pulse while 1x long stroke would be pulse-pulse-pulse-pulse?
No, unfortunately not: basically there's a reed switch on a mounting inside the housing, and a magnet mounted on the wheel the cord is wrapped onto (not on the flywheel). So, it pulses no matter which direction the wheel is running. BTW, when I say pulse, I just mean the reed switch opens.
And the number of pulses is quite variable; either 4 or 5 in each direction (and sometimes the magnet will be over the switch at the end of the pull, so I get 9 in total).
elvon_blunden:
But of course the nature of rowing is that you can sit with your legs stretched and not move the seat, yet still do a full stroke on the rope with your arms and waist...
Yup, and this was the thinking behind tracking the seat position and maybe using it somehow in the distance calculations - I guess there is some optimum sequence of movements. By measuring the time between pulses I could get the speed I'm pulling the oar at 3 or 4 points in the stroke, and by measuring the seat position I can tell whether I'm doing it with my legs or arms/body. The idea would be that if I do the stroke "right" I would get better distance.
elvon_blunden:
(Interesting that the PM5 computer on a Concept2 costs 155GBP which is about what I think you said your ergo cost
It is! I think all mine does is count the pulses from the cord wheel, and multiply by fixed factors to get strokes, calories and miles!
