Measuring Wet Bulb Temperature?
Hi there,
I would like to detect frost for my apple trees and thought I'd play around with arduino.
It turns out that you need to measure the Wet Bulb temperature.
As far as I see this is usually done wrapping the sensor in wet cloth.
Does anyone have any experience with such measurements/calculations? What's the easiest way to do this.
Is it possible to use a normal sensor like the BME280 and infer the wet bulb temperature using relative humidity, dry bulb temperature and maybe a wind meter?
Thank you very much!
Yes that is right.
You can but the sensor will not be very accurate and this will reflect in the answer you get. I don’t know how accurate you need to be.
This is a link to the formula you need to use. Just manipulate them to make the subject of the equation equal to the value you want.
No, you need a hot wire anemometer or a cup or ultrasonic anemometer for that. Note any humidity measurements must be shielded from the wind otherwise the results are not valid.
I'm intrigued by what you can do if you do detect frost conditions?
I suppose you could light fires and waft the warm air around with boards strapped to your arms. Like in that movie... can't remember the name. It was vines they were trying to protect from frost.
PaulRB:
Smudge pots were commonly used in the past, although I've never heard of anyone trying to stir the air with boards strapped to their arms. Google does turn up a lot of references to using large fans for frost protection.
A lot easier to turn on the irrigation and spray water onto the plants, although with an apple tree that might be difficult. Around here, the technique is commonly used for strawberry plants, and the news companies seem to love sending a reporter out to get pictures of a field of plants covered in ice.
It was A Walk In The Clouds from 1995 starring Keanu Reeves.
The BME is staggeringly accurate. Calculating the wet bulb from that data is just maths.
Dew point is also another calculation you might use.
Hi All,
Both thermocouples and thermistors can
be used as wet bulb thermometers.
Herb
herbschwarz:
Without keeping them wet? Please explain how.
You can calculate wet bulb temp from dry bulb, pressure and humidity, from what this thread seems to show.
https://forum.arduino.cc/index.php?topic=238265.0
Also google
wet bulb ds18b20
and
ds1820 arduino
DS1820 are made in sealed metal tube to make them weather proof.
Tom.... :slight_smile:
TomGeorge:
Although that seems to be a trifle dubious according to some reports!
I think what you need to know is the "dew point" temperature.
The dew point is the temperature to which air must be cooled to become saturated with water vapor. When further cooled, the airborne water vapor will condense to form liquid water (dew). When air cools to its dew point through contact with a surface that is colder than the air, water will condense on the surface. When the temperature is below the freezing point of water, the dew point is called the frost point, as frost is formed rather than dew. The measurement of the dew point is related to humidity. A higher dew point means there will be more moisture in the air.
Tom.. :slight_smile:
