Hi all
I started to make this very nice project of a hardware surface to control an existing Replay software (Slow motion and all the stuff included
I'm exited with this project because I don't know about programming, but I jumped on it without fear because Arduino and this community can help me make it happen.
Note: "For you have an idea of how newbie I am, my first mistake was to get a Mega board... now I have to change it for a Due, because I didn't know that the Mega can't send out keyboard commands."
Now the problem
Components:
5 Shift Registers for 36 Leds ( 74HC595 )
5 Shift Registers for 36 Buttons ( CD4021BE )
3 Modules for 3 OLED and LCD displays ( I2C )
This project will have 7 stages:
1- Breadboard based development surface (Done)
2- Leds (Right side wired and testing) Shift Registers
3- Buttons (Right side installed but not wired)
4- Displays (Right side installed but not wired)
5- Keyboard commands triggered by the surface buttons
6- PCB
7- Final enclosure
At the stage I am now (Leds testing) the attached code is working... but I would like to know if there is a simpler code to turn on for example the led #3 that is controlled by the shift register #1.
Please remember that the final circuit will end with 5 shift registers controlling 36 leds... now, there is only 2 wired.
Please, let me know if I'm going the right direction and what you think about the breadboard working surface I made ( I put a lot of effort to make it as clean and nice as possible... did you notice even those elastic black bands to hold the cables?... I'm so proud
I'm posting several pics and a drawing of how will look the surface once finalized and the final selected buttons!!! (of course, now I have only those... I'm using a cheaper ones for now, will buy them when everything is ready)
Thank you in advance
Luis
Here is the "leds" code:
int datapin_leds = 23;
int clockpin_leds = 24;
int latchpin_leds = 22;
uint16_t data = 0;
 pinMode(datapin_leds, OUTPUT);
 pinMode(clockpin_leds, OUTPUT);
 pinMode(latchpin_leds, OUTPUT);
 Section2leds();
void shiftWrite(int desiredPin, boolean desiredState)
 digitalWrite(latchpin_leds, LOW);
 if (desiredState)
  data |= (1 << desiredPin);
  data &= ~(1 << desiredPin);
 shiftOut(datapin_leds, clockpin_leds, MSBFIRST, data >> 8);
 shiftOut(datapin_leds, clockpin_leds, MSBFIRST, data);
 digitalWrite(latchpin_leds, HIGH);
void Section2leds()
 int LedsArray[16] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15};
 shiftWrite(LedsArray[2], HIGH);
