MEGA2560 Serial Communication
I am using the RX/TX lines to communicate with a 4D display panel model uLCD-32PTU. It works great on the bench. But when I used it in the application environment, It become erratic and mostly not working. The distance between the MEGA2560 and the display panel becomes about 25 feet. I am using regular MIL-STD 20 Gage wire to connect the RESET, RX, TX and Power and GND. Does anyone have any ideas why?
I am not sure if the distance has anything to do with it. Because when I increase the wire length to 25 feet on then bench, everything woks fine. Am I getting EMI, or noise from somewhere? Is there any way to eliminate that?
Thanks
Bobby
You may want to try STP (Shielded Twisted Pair) cable if not using shielded cable already.
Ron
  • Probably.
  • Does the display send data to the Arduino ? :thinking:
  • Google TTL to 485 converter
Hello,
I have used the RS485 as you suggested. But something is very intermittent. It sometimes works and sometimes does not. even when they are 3 feet apart. If I connect the TX/RX out of the MEGA2560 straight to the RX/TX of the 4D display uLCD32PTU with about 3 feet of wires, everything works. If I increase the distance to 25 feet then it sometimes work and sometimes does not. I tried twisted shielded wire. It make it worse. I can see corrupted signal on the RX line getting into the display. The RESET line on the display panel is not connected to anything. We tried connecting it to the MEGA2560 to toggle it at the power up. But it caused problems with other display panels. We are connecting 3 display panels to the Mega2560 using 3 serial ports. The program is attached for more info. The problem is very intermittent. I have changed display panels 3 times and MEGA2560 3 times. They all do the same thing. All three display panels worked great on the bench connected to the MEGA2560.
Thank You
Bobby
Here is the program.
Thanks
Bobby
//#include <genieArduino.h>
// When one of the 4D display panels goes bad or get disconnected, the other 2 do not work and update
// The problem is that the display panels loose the SYNC.
// So the <genieArduinoDEV.h> is added to fix the problem.
#include <genieArduinoDEV.h>
#include <SoftwareSerial.h>   // need this to make the arrow part of color picker to work
  A350 CRC Touch Screen seating area Display Panel
  This program is installed in the CRC Main COntroller.
  This program uses Ardunio MEGA 2560 board along with 3 of the 4D system touch screen uLCD-32PTU
  The Ardunio communnicates with 4D touch screens via serial ports 1, 2, 3
  All touch screen display are used in the Seating area of the A350 CRC module.
  Serial Port 0 is used to comunicate with the Alarm display panel to get
  Smoke location and then send it to all the touch screen display panels
// Serial Port 0 is used to communicate with Alarm Display Panel
// Serial Port 1 is used to communicate with the 4D display #1
// Serial Port 2 is used to communicate with the 4D display #2
// Serial Port 3 is used to communicate with the 4D display #3
// Location of  the Smoke comes from the Alarm Display Panel in form of 1 to 14 for the A350 CRC.
// And value of 20 is used for multiple fire locations
// These location is used here to show te location. Only these values should turn on the
// Smoke ICON on the main menu.
// OCTOBER 2023. ADDED AN IF STATEMENT FOR DISCRETE SMOKE INPUT. IF IT IS LOW THEN TUNR ON THE SMOKE
// ICON IN THE MAIN MENU OF THE SEATING AREA DISPLAY PANELS. IT ALSO TURNS THE SMOKE ON WHEN IT GETS
// MESSAGES FROM THE ALARM DISPLAY PANEL. BUT IT ALSO SHOULD TURN ON THE SMOKE ICON WHEN THE DISCRET
// SMOKE INPUT GOES LOW. REDUDENCY
// CHANGED TO SMOKE = 1 ON MARCH 2024
Genie display1; // Genie Display 1
Genie display2; // Genie Display 2
Genie display3; // Genie Display 2
//Genie genie;
// Mood Lighting
int RED, GREEN, BLUE = 0;
int UP_WARD, LAV_OCP, LAV_DWR, CRC_DR, SMOKE, SMOKE1, VALVE_SW1, VALVE_SW2, LOW_AIR, HATCHES, C, HATCH1, HATCH2, CAB_RTN, BELT, CEILING, FLOOR;
int incomingByte, counter;      // incoming serial data from Alarm display Panel providing Alarm Location
      // USe serial 0 to communicate to the Alarm Display Panel to get location of the Alarms
     Serial1.begin(9600);   // Serial1 should match the speed set in the 4D display
  display1.Begin(Serial1);   // Use Serial0 for talking to the Genie Library, and to the 4D Systems display #1
  Serial2.begin(9600);  // Serial2 should match the speed set in the 4D display
  display2.Begin(Serial2);  // Use Serial1 for talking to the Genie Library, and to the 4D Systems display #2
  Serial3.begin(9600);  // Serial2 should match the speed set in the 4D display
  display3.Begin(Serial3);  // Use Serial1 for talking to the Genie Library, and to the 4D Systems display #2
  display1.AttachEventHandler(myGenieEventHandler1); // Attach the user function Event Handler for processing events for display 1
  display2.AttachEventHandler(myGenieEventHandler2); // Attach the user function Event Handler for processing events for display 2
  display3.AttachEventHandler(myGenieEventHandler3); // Attach the user function Event Handler for processing events for display 2
/* This Touch screen reset function was removed because it causes all three touch screens to turn on
   and then turn off and do not turn back on. it was worse when the Alarm Display panel
   was powered On too. Some times they came on but the serial ports never could communicate
   with MEGA2560. I think the problem started when I added #include <genieArduinoDEV.h>
   This file syncs all the touch screen so the RESET function probably causes interference.
  // Reset the Displays
  // THIS IS IMPORTANT AND CAN PREVENT OUT OF SYNC ISSUES, SLOW SPEED RESPONSE ETC
  pinMode(4, OUTPUT);  // Set D4 on Arduino to Output to control the reset line to Display 1
  pinMode(3, OUTPUT);  // Set D2 on Arduino to Output to control the reset line to Display 2
  pinMode(2, OUTPUT);  // Set D2 on Arduino to Output to control the reset line to Display 2
  digitalWrite(4, 1);  // Reset Display 1
  digitalWrite(3, 1);  // Reset Display 1
  digitalWrite(2, 1);  // Reset Display 2
  delay(100);
  digitalWrite(4, 0);  // unReset Display 1
  digitalWrite(3, 0);  // unReset Display 1
  digitalWrite(2, 0);  // unReset Display 2
  // Let the display start up after the reset (This is important)
  // Increase to 4500 or 5000 if you have sync problems as your project gets larger. Can depent on microSD init speed.
  delay (5000);
    pinMode(22, INPUT);
    pinMode(23, INPUT);
    pinMode(24, INPUT);
    pinMode(25, INPUT);
    pinMode(26, INPUT);
    pinMode(27, INPUT);
    pinMode(28, INPUT);
    pinMode(29, OUTPUT);
    pinMode(30, INPUT);
    pinMode(31, INPUT);
    pinMode(32, INPUT);
    pinMode(33, INPUT);
    pinMode(34, INPUT);
    pinMode(35, OUTPUT);
    pinMode(36, OUTPUT);
    pinMode(37, OUTPUT);
    pinMode(52, OUTPUT);    // TO CONTROL RTS ON THE RS485 MODULE LOCATED IN THE MAIN CONTROLLER
    pinMode(53, OUTPUT);    // TO CONTROL RTS ON THE RS485 LOCATED IN THE SEATING AREA DISPLAY PANELS. USING RESET WIRE.
    // For Mood Lighting - Environmental RGB Lights are limited to 25 feet. more than that the colors dont work.
    // So we need to channels - circuits
    pinMode(7, OUTPUT);     // green - pin 7
    pinMode(6, OUTPUT);    // blue color - pin 6
    pinMode(5, OUTPUT);    // for red color - pin 5
    pinMode(11, OUTPUT);     // green - pin 7
    pinMode(10, OUTPUT);    // blue color - pin 6
    pinMode(9, OUTPUT);    // for red color - pin 5
    // Initialize
    CEILING=0;
    FLOOR=0;
    SMOKE = 0;
    counter = 0;
  display1.DoEvents(); // This calls the library each loop to process the queued responses from display 1
  display2.DoEvents(); // This calls the library each loop to process the queued responses from display 2
  display3.DoEvents(); // This calls the library each loop to process the queued responses from display 3
    STATUS();
        // genie.DoEvents();  //Here the messages are received and queued.
  if (Serial.available() > 0)
    incomingByte = Serial.read();
// This is the user's event handler. It is called by the DoEvents()
// when the following conditions are true
//    The link is in an IDLE state, and
//    There is an event to handle
// The event can be either a REPORT_EVENT frame sent asynchronously
// from the display or a REPORT_OBJ frame sent by the display in
// response to a READ_OBJ (genie.ReadObject) request.
// Event Handler Function for Display 1
void myGenieEventHandler1(void)
  genieFrame Event;
  display1.DequeueEvent(&Event); // Remove the next queued event from the buffer, and process it below
  //If the cmd received is from a Reported Event (Events triggered from the Events tab of Workshop4 objects)
  if (Event.reportObject.cmd == GENIE_REPORT_EVENT)
    if (Event.reportObject.object == GENIE_OBJ_WINBUTTON)// If the reported message is from a Winbutton
//      Serial1.println(Event.reportObject.index);          // Now we need to convert data to HEX
     if (Event.reportObject.index == 0)              // If the reported message is from Winbutton0
        if (CEILING == 0)
        digitalWrite(36, 1);          //Turn On the Ceiling Lights
        CEILING = 1;                 // Use to toggle On/Off
        digitalWrite(36, 0);          //Turn Off the Ceiling Lights
        CEILING = 0;
       if (Event.reportObject.index == 9)              // If the reported message is from Winbutton9 - turn off Mood lighting
            digitalWrite(35, 0);                    //Turn Off POWER FOR MOOD LIGHTING
     if (Event.reportObject.index == 3)              // If the reported message is from Winbutton3
            digitalWrite(35, 0);                    //Added Turn Off POWER FOR MOOD LIGHTING
            delay (2000);
            RED=255;
            GREEN=0;
            BLUE=0;
            digitalWrite(35, 1);                    //Turn On POWER FOR MOOD LIGHTING
            //Channel 1
            analogWrite(5,  RED);                   // Turn On the mood lighting color 1
            analogWrite(7, GREEN);
            analogWrite(6, BLUE);
            //Channel 2
            analogWrite(9,  RED);                   // Turn On the mood lighting color 1
            analogWrite(11, GREEN);
            analogWrite(10, BLUE);
     if (Event.reportObject.index == 4)              // If the reported message is from Winbutton4
            digitalWrite(35, 0);                    //AddedcTurn Off POWER FOR MOOD LIGHTING
            delay (2000);
            RED=0;
            GREEN=255;
            BLUE=255;
            analogWrite(5,  RED);                   // Turn On the mood lighting color 2
            //Channel 2
     if (Event.reportObject.index == 11)              // If the reported message is from Winbutton11
            delay (2000);
            RED=0;
            GREEN=128;
            BLUE=0;
            //Channel 2
     if (Event.reportObject.index == 12)              // If the reported message is from Winbutton12
            delay (2000);
            RED=0;
            GREEN=0;
            BLUE=255;
            //Channel 2
    if (Event.reportObject.index == 18)              // If the reported message is from Winbutton18
            delay (2000);
            RED=255;
            GREEN=255;
            BLUE=255;
            //Channel 2
// Read input status of inputs and send out to seating display panels
void STATUS()
        // GND is active for all these lines
        UP_WARD = digitalRead(22);   // Read status of pin 22 - WARDRUP SW NOT USED - NOT CONNECTED
        LAV_OCP = digitalRead(23);   // Read status of pin 23 - LAV OCCUPIED
        HATCH1 = digitalRead(24);    // Read status of pin 24 - HATCH1
        HATCH2 = digitalRead(25);    // Read status of pin 25 - HATCH2
        SMOKE =   digitalRead(26);   // Read status of pin 26 - SMOKE. High IS SMOKE PRESENT
        VALVE_SW1 = digitalRead(27); // Read status of pin 27 - SHUTOFF VALVE #1
        VALVE_SW2 = digitalRead(28); // Read status of pin 28 - SHUTOFF VALVE #2
        CAB_RTN = digitalRead(31);   // Read status of pin 31 - Return to Cabin
        BELT = digitalRead(32);      // Read status of pin 32 - Fasten Seat Belt
//        digitalWrite(52, 1);        //SET RTS LOCATED IN THE MAIN CONTROLLER TO HI ON THE RS485 MODULE TO SEND DATA OUT
//        digitalWrite(53, 0);        //SET RTS LOCATED ON THE RS485 MODULE TO LOW IN THE DISPLAY PANELS IN THE SEATING AREA TO RECEIVE DATA
// Added October 2023. The SMOKE discrete coming from Alarm Display Panel
        if (SMOKE == 1)
// Turn on the Smoke Icon
            display1.WriteObject(GENIE_OBJ_USERIMAGES, 3, 1);         //Write to Smoke Userimages3 shown in 4D display
            display2.WriteObject(GENIE_OBJ_USERIMAGES, 3, 1);         //Write to Smoke Userimages3 shown in 4D display
            display3.WriteObject(GENIE_OBJ_USERIMAGES, 3, 1);         //Write to Smoke Userimages3 shown in 4D display
           // Turn off the Smoke Icon
            display1.WriteObject(GENIE_OBJ_USERIMAGES, 3, 0);         //Write to Smoke Userimages3 shown in 4D display
            display2.WriteObject(GENIE_OBJ_USERIMAGES, 3, 0);         //Write to Smoke Userimages3 shown in 4D display
            display3.WriteObject(GENIE_OBJ_USERIMAGES, 3, 0);         //Write to Smoke Userimages3 shown in 4D display
        if (LAV_OCP == 1)
          display1.WriteObject(GENIE_OBJ_USERIMAGES, 0, 0);         //Write to Userimages0 shown in 4D display - Lavatory
          display2.WriteObject(GENIE_OBJ_USERIMAGES, 0, 0);         //Write to Userimages0 shown in 4D display - Lavatory
          display3.WriteObject(GENIE_OBJ_USERIMAGES, 0, 0);         //Write to Userimages0 shown in 4D display - Lavatory
          display1.WriteObject(GENIE_OBJ_USERIMAGES, 0, 1);         //Write to Userimages0 shown in 4D display - Lavatory
          display2.WriteObject(GENIE_OBJ_USERIMAGES, 0, 1);         //Write to Userimages0 shown in 4D display - Lavatory
          display3.WriteObject(GENIE_OBJ_USERIMAGES, 0, 1);         //Write to Userimages0 shown in 4D display - Lavatory
        if (CAB_RTN == 0)
         display1.WriteStr(2, "           ");                   // Send string 2 to 4D touch screen
         display2.WriteStr(2, "           ");                   // Send string 2 to 4D touch screen
         display3.WriteStr(2, "           ");                   // Send string 2 to 4D touch screen
          display1.WriteStr(2, "Return to Cabin");                   // Send string 2 to 4D touch screen
          display2.WriteStr(2, "Return to Cabin");                   // Send string 2 to 4D touch screen
          display3.WriteStr(2, "Return to Cabin");                   // Send string 2 to 4D touch screen
        if (BELT == 0)
          display1.WriteObject(GENIE_OBJ_USERIMAGES, 1, 0);         //Write to Userimages1 shown in 4D display - FasteN Belt
          display2.WriteObject(GENIE_OBJ_USERIMAGES, 1, 0);         //Write to Userimages1 shown in 4D display - FasteN Belt
          display3.WriteObject(GENIE_OBJ_USERIMAGES, 1, 0);         //Write to Userimages1 shown in 4D display - FasteN Belt
          display1.WriteObject(GENIE_OBJ_USERIMAGES, 1, 1);         //Write to Userimages1 shown in 4D display - Faster Belt
          display2.WriteObject(GENIE_OBJ_USERIMAGES, 1, 1);         //Write to Userimages1 shown in 4D display - Faster Belt
          display3.WriteObject(GENIE_OBJ_USERIMAGES, 1, 1);         //Write to Userimages1 shown in 4D display - Faster Belt
        // Send data to display #1
        display1.WriteObject(GENIE_OBJ_USER_LED, 0, LAV_OCP);         //Write to userled1 of the 4D display -
        display1.WriteObject(GENIE_OBJ_USER_LED, 1, HATCH1);         //Write to userled1 of the 4D display -
        display1.WriteObject(GENIE_OBJ_USER_LED, 2, VALVE_SW1);         //Write to userled1 of the 4D display -
        display1.WriteObject(GENIE_OBJ_USER_LED, 3, VALVE_SW2);         //Write to userled1 of the 4D display -
        display1.WriteObject(GENIE_OBJ_USER_LED, 4, HATCH2);         //Write to userled1 of the 4D display -
        display1.WriteObject(GENIE_OBJ_USER_LED, 5, SMOKE);         //Write to userled1 of the 4D display -
        // Send data to display #2
        display2.WriteObject(GENIE_OBJ_USER_LED, 0, LAV_OCP);         //Write to userled1 of the 4D display -
        display2.WriteObject(GENIE_OBJ_USER_LED, 1, HATCH1);         //Write to userled1 of the 4D display -
        display2.WriteObject(GENIE_OBJ_USER_LED, 2, VALVE_SW1);         //Write to userled1 of the 4D display -
        display2.WriteObject(GENIE_OBJ_USER_LED, 3, VALVE_SW2);         //Write to userled1 of the 4D display -
        display2.WriteObject(GENIE_OBJ_USER_LED, 4, HATCH2);         //Write to userled1 of the 4D display -
        display2.WriteObject(GENIE_OBJ_USER_LED, 5, SMOKE);         //Write to userled1 of the 4D display -
        // Send data to display #3
        display3.WriteObject(GENIE_OBJ_USER_LED, 0, LAV_OCP);         //Write to userled1 of the 4D display -
        display3.WriteObject(GENIE_OBJ_USER_LED, 1, HATCH1);         //Write to userled1 of the 4D display -
        display3.WriteObject(GENIE_OBJ_USER_LED, 2, VALVE_SW1);         //Write to userled1 of the 4D display -
        display3.WriteObject(GENIE_OBJ_USER_LED, 3, VALVE_SW2);         //Write to userled1 of the 4D display -
        display3.WriteObject(GENIE_OBJ_USER_LED, 4, HATCH2);         //Write to userled1 of the 4D display -
        display3.WriteObject(GENIE_OBJ_USER_LED, 5, SMOKE);         //Write to userled1 of the 4D display -
// Event Handler Function for Display 2
void myGenieEventHandler2(void)
  genieFrame Event;
  display2.DequeueEvent(&Event); // Remove the next queued event from the buffer, and process it below
        if (CEILING == 0)
        CEILING = 0;
            delay (2000);
            RED=255;
            GREEN=0;
            BLUE=0;
            //Channel 2
            delay (2000);
            RED=0;
            GREEN=255;
            BLUE=255;
            //Channel 2
            delay (2000);
            RED=0;
            GREEN=128;
            BLUE=0;
            //Channel 2
            delay (2000);
            RED=0;
            GREEN=0;
            BLUE=255;
            //Channel 2
            delay (2000);
            RED=255;
            GREEN=255;
            BLUE=255;
            //Channel 2
// Event Handler Function for Display 3
void myGenieEventHandler3(void)
  genieFrame Event;
  display3.DequeueEvent(&Event); // Remove the next queued event from the buffer, and process it below
//      Serial3.println(Event.reportObject.index);          // Now we need to convert data to HEX
        if (CEILING == 0)
        CEILING = 0;
            delay (2000);
            RED=255;
            GREEN=0;
            BLUE=0;
            //Channel 2
            delay (2000);
            RED=0;
            GREEN=255;
            BLUE=255;
            //Channel 2
            delay (2000);
            RED=0;
            GREEN=128;
            BLUE=0;
            //Channel 2
            delay (2000);
            RED=0;
            GREEN=0;
            BLUE=255;
            //Channel 2
            delay (2000);
            RED=255;
            GREEN=255;
            BLUE=255;
            //Channel 2
Seating_Displays.ino (56.7 KB)
Hello,
I just found out that with short wires, the TX line out of the 4D touch screen to the RX line of the MEGA2560 looks good as shown in the picture attached.
But with wire about 15 feet, it looks noisy. And that is when it does not work.
Any idea how I can clean up the noise on the wire. Please look at the pictures on the scope.
Thanks
Bobby
TX out of Display Bad
TX out of Display Good
Hello,
After doing more testing, I found out more data. The problem is the 4D System
display panel uLCD-32PTU needs it's TX line to be connected to the Arduino RX line.
All I like to do is to send data out of ARDUINO to the uLCD-32PTU. Since the Display Panel is not sending anything out, I did not connect the TX of the Display Panel to the RX of the Arduino. I did this on the bench with 3 feet of cable. No RS485 in the middle.
It does not work this way. I used 3 different Display Panels and 2 Arduino boards. It wants the RX and TX lines connected. Any idea why?
I then connected the RS485 on both sides. Arduino sending out data and Display receiving it. Same as shown in your drawing. It does not work.
But if I do not connect the TX pin of the Display Panel to the RS485, and do not connect the RX line of the Arduino to its RS485. And then connect the TX to the RX bypassing the RS485 modules, everything works fine.
This defeat the purpose of the RS485. Anyone has any idea what is going on. Is there anyway I can setup the Display Panel uLCD-32PTU TX line to bypass this problem?
Thanks
Bobby
