Hello everyone.
I am working on a hobby project to monitoring things at home. Now I am working with pH probes and conductivity probes for my aquario.
So this probes (Atlas Scientifics probes) has several options: you can ser a name, reset, power on/off led, calibrating... So I made a sketch with a brief menú so configuration is much easier.
I am working with arduino uno and have 32Kbytes of memory. The problem I have is that when I reach more or less 11,5 KB, the programa gets Crazy. I have program the same but with different code (to see if it was my mistake) and the same problem.
What happens bassically for example, I have a 5 option in my menú and control the option with a switch case statement. So for example I start the program and with not touching nothing (by default only appears the menu and I have to write in a number which I send by SPI from computer and with that I select in the switch case statement) the Serial.print inside the cases appears. Anything you can imagine happens, what I think is that the program is bad allocated un memory, because sometimes funcions that I do not call get executed and so on.
I know code is correct because if I start commenting Serial.print to reduce memory, everything works well.
Anyone experiencias can help me?
Thanks so much
