I bought This RFID reader http://www.ebay.com/itm/161135300790?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 and Im trying to integrate it into a project Im doing. All i really need from the RFID reader is a bare read out of the RFID tags and cards. Im using the library from GitHub - miguelbalboa/rfid: Arduino RFID Library for MFRC522 and everything is working well when i upload the dump code sketch and im getting readings from my Arduino.
This is that code
* MFRC522 - Library to use ARDUINO RFID MODULE KIT 13.56 MHZ WITH TAGS SPI W AND R BY COOQROBOT.
* The library file MFRC522.h has a wealth of useful info. Please read it.
* The functions are documented in MFRC522.cpp.
* Based on code Dr.Leong ( WWW.B2CQSHOP.COM )
* Created by Miguel Balboa (circuitito.com), Jan, 2012.
* Rewritten by Søren Thing Andersen (access.thing.dk), fall of 2013 (Translation to English, refactored, comments, anti collision, cascade levels.)
* Released into the public domain.
* Sample program showing how to read data from a PICC using a MFRC522 reader on the Arduino SPI interface.
*----------------------------------------------------------------------------- empty_skull
* Aggiunti pin per arduino Mega
* add pin configuration for arduino mega
* http://mac86project.altervista.org/
----------------------------------------------------------------------------- Nicola Coppola
* Pin layout should be as follows:
* Signal Pin Pin Pin
* Arduino Uno Arduino Mega MFRC522 board
* Reset 9 5 RST
* SPI SS 10 53 SDA
* SPI MOSI 11 52 MOSI
* SPI MISO 12 51 MISO
* SPI SCK 13 50 SCK
* The reader can be found on eBay for around 5 dollars. Search for "mf-rc522" on ebay.com.
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
Serial.begin(9600); // Initialize serial communications with the PC
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
Serial.println("Scan PICC to see UID and type...");
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
// Dump debug info about the card. PICC_HaltA() is automatically called.
mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
and this is what it reads when I scan a tag
Card UID: 55 68 F1 B0
PICC type: MIFARE 1KB
Sector Block 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 AccessBits
15 63 PCD_Authenticate() failed: Timeout in communication.
14 59 PCD_Authenticate() failed: Timeout in communication.
13 55 PCD_Authenticate() failed: Timeout in communication.
12 51 PCD_Authenticate() failed: Timeout in communication.
11 47 PCD_Authenticate() failed: Timeout in communication.
10 43 PCD_Authenticate() failed: Timeout in communication.
9 39 PCD_Authenticate() failed: Timeout in communication.
8 35 PCD_Authenticate() failed: Timeout in communication.
7 31 PCD_Authenticate() failed: Timeout in communication.
6 27 PCD_Authenticate() failed: Timeout in communication.
5 23 PCD_Authenticate() failed: Timeout in communication.
4 19 PCD_Authenticate() failed: Timeout in communication.
3 15 PCD_Authenticate() failed: Timeout in communication.
2 11 PCD_Authenticate() failed: Timeout in communication.
1 7 PCD_Authenticate() failed: Timeout in communication.
0 3 PCD_Authenticate() failed: Timeout in communication.
All i need is the Card UID. Is there a way i can get bare 55 68 F1 B0 as a data type?
Please help
