Hello , im doing Final year project using arduino in my project im using 2 mg995r servo motors so i need an external power supply for the motors so i checked a powerbank that i have and the ouput voltage are 5V 3A,9V 2A, 12V 1.5A(Note there is only 1 USB port as output) So my question is if i connect the two motors in parallel will i get the 5V 3A? Will it work? Because i need 1.5A approximately for each motor
Welcome! I am not exactly sure of what you are asking. You should be able to run two motors but not concurrently because of there inrush. I suggest you get at least a 5A power source.
Im asking if the powerbank i showed above will be suitable as a power supply for the 2 motors
Depends on how you run them! Concurrent means operating or occurring at the same time, or acting in conjunction. Concurrently Definition & Meaning - Merriam-Webster
Go to this link:What is inrush current in an AC motor and why does it matter?
Hopefully this answers your question.
