I wan to use a PLC to trigger an ESP32/STM32 micro-controller that controls two 24 V RGB LED strips to display a Red → Yellow → Green countdown based on a process signal
Is the Flow chart described below correct?
2 . Can someone suggest some cheap micro-controller (1 input and 2 or more output) and voltage converter for my case
I suggest you get a copy of the Arduino Cookbook and then skim it cover to cover, you should find most if not all of your answer including code and wiring information
