Micromouse simulator usage with arduino
#include <stdio.h>
#include <stdlib.h>
#include <stdbool.h>
#define MAX_SIZE 100
#define Row 16
#define Column 16
//forming queue data structure
struct Queue {
int items[MAX_SIZE];
int front;
int rear;
struct Queue* queue;
// Function to create an empty queue
struct Queue* createQueue() {
struct Queue* queue = (struct Queue*)malloc(sizeof(struct Queue));
queue->front = -1;
queue->rear = -1;
return queue;
// Function to check if the queue is full
int isFull(struct Queue* queue) {
return (queue->rear == MAX_SIZE - 1);
// Function to check if the queue is empty
int isEmpty(struct Queue* queue) {
return (queue->front == -1 && queue->rear == -1);
// Function to add an element to the queue
void enqueue(struct Queue* queue, int value) {
if (isFull(queue)) {
Serial.println("Queue is full, cannot enqueue!");
return;
if (isEmpty(queue)) {
queue->front = 0;
queue->rear = 0;
queue->rear++;
queue->items[queue->rear] = value;
// Function to remove an element from the queue
void dequeue(struct Queue* queue) {
Serial.println("Queue is empty, cannot dequeue!");
return;
if (queue->front == queue->rear) {
queue->front = -1;
queue->rear = -1;
queue->front++;
// Function to get the front element of the queue
int front(struct Queue* queue) {
Serial.println("Queue is empty!");
return -1;
return queue->items[queue->front];
// Function to display the queue
void display(struct Queue* queue) {
return;
Serial.println("Queue elements: ");
for (int i = queue->front; i <= queue->rear; i++) {
Serial.println(queue->items[i]);
Serial.println("\n");
//declaring global variables
byte grid[16][16];
byte walls[16][16][4];
byte start_x = 0;
byte start_y = 0;
byte orientation = 0;
//directions
//up = 0
//right = 1
//down = 2
//left = 3
byte min_val = 0;
byte direction = 0;
byte front_x = 0;
byte front_y = 15;
Serial.begin(19200);
//initial flood grid
for (int i = 0;i < Row;i++){
for (int j = 0;j < Column;j++){
if (i < 8 && j < 8){
grid[i][j] = byte(abs(i-7) + abs(j-7));
else if (i > 7 && j < 8){
grid[i][j] = byte(abs(i-8) + abs(j-7));
else if (i < 8 && j > 7){
grid[i][j] = byte(abs(i-7) + abs(j-8));
else {
grid[i][j] = byte(abs(i-8) + abs(j-8));
//printing out flood grid
for (int j = 0;j < 16;j++) {
for (int i = 0;i < 16;i++){
Serial.println(grid[i][j]);
//initial wall grid with all four values equal to 4
        for (int k = 0;k < Column;k++){
            walls[i][j][k] = 4;
//inserting wall values in array of given cell
void insert(byte start_x, byte start_y,byte value){
for (int k = 0;k < 4;k ++){
if (walls[start_x][start_y][k] > 3){
walls[start_x][start_y][k] = byte(value);
//checking for wall in a cell
bool check_wall(byte start_x,int start_y, byte wall_direct){
if (walls[start_x][start_y][k] == byte(wall_direct)){
return 1;
return 0;
//finding reachable neighbours
void find_neighbour(byte start_x,byte start_y){
//upper wall
if((start_y - 1) > 0){
if((!check_wall(start_x,start_y,0))){
enqueue(queue,start_x);
enqueue(queue,(start_y - 1));
//down wall
if ((start_y + 1) < Column){
if ((!check_wall(start_x,start_y,2))){
enqueue(queue,(start_y + 1));
//right wall
if((start_x + 1) < Row){
if((!check_wall(start_x,start_y,1))){
enqueue(queue,(start_x + 1));
enqueue(queue,start_y );
//left wall
if((start_x - 1) > 0){
if((!check_wall(start_x,start_y,3))){
enqueue(queue,(start_x - 1));
enqueue(queue,start_y);
//finding least value cell
int min_val_cell(byte start_x,byte start_y){
if ((start_y - 1) > 0){
    min_val = grid[start_x][start_y - 1];
else if ((start_x + 1) < Row){
    min_val = grid[start_x + 1][start_y];
else if ((start_y + 1) < Column){
    min_val = grid[start_x][start_y + 1];
else if ((start_x - 1) > 0){
    min_val = grid[start_x - 1][start_y];
if ((start_x + 1) < Row && min_val > grid[start_x + 1][start_y]){
    direction = 1;
if ((start_y + 1) < Column && min_val > grid[start_x][start_y + 1]){
    direction = 2;
if ((start_x - 1) > 0 && min_val > grid[start_x - 1][start_y]){
    direction = 3;
if ((start_y - 1) > 0 && min_val > grid[start_x - 1][start_y]){
    direction = 0;
return (min_val);
void orienting(byte direction){
//orienting up
if (direction == 0){
if (orientation == 1){
turnLeft();
else if (orientation == 2){
turnLeft();
turnLeft();
else if (orientation == 3){
turnLeft();
orientation = 0;
//orienting right
if (direction == 1){
if (orientation == 0){
turnRight();
turnLeft();
turnLeft();
turnLeft();
orientation = 1;
//orienting down
if (direction == 2){
turnLeft();
turnLeft();
else if (orientation == 1){
turnRight();
turnLeft();
orientation = 2;
//orienting left
if (direction == 3){
turnLeft();
turnLeft();
turnLeft();
turnRight();
orientation = 3;
orientation = direction;
while (true){
//  if (grid[start_x][start_y] == 0){
//        while (1){
    min_val = 0;
    direction = 0;
    min_val_cell(start_x,start_y);
//orienting up
    orienting(direction);
//checking right wall
    if (wallRight){
            insert(start_x,start_y,1);
                insert(start_x + 1,start_y,3);
            insert(start_x,start_y,3);
                insert(start_x - 1,start_y,1);
            insert(start_x,start_y,2);
                insert(start_x,start_y + 1,0);
            insert(start_x,start_y,0);
                insert(start_x,start_y - 1,2);
//checking left wall
    if (wallLeft){
                insert(start_x,start_y + 1,3);
    if (!wallFront()){
        moveForward();
        start_y -= 1;
        start_x += 1;
        start_y += 1;
        start_x -= 1;
    else{
    //storing walls
//using floodfill algorithm
        while (!isEmpty(queue)){
            front_x = front(queue);
            dequeue(queue);
            front_y = front(queue);
            dequeue(queue);
            find_neighbour(front_x,front_y);
            if (grid[front_x][front_y] <= min_val_cell(front_x,front_y)){
                grid[front_x][front_y] = min_val_cell(front_x,front_y) + 1;
The problem here is that I am not able to upload this code to arduino because some functions like wallFront turnRight etc are not defined by me but by the mms-arduino api.
It's github link is heremicromouse simulator with arduino.
People please come forward for help!!
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Hi, what is the exact error message that you're seeing?
This is the error msg i am seeing
C:\Users\zoome\OneDrive\Desktop\maze solver\mms-arduino\mms-arduino.ino: In function 'void orienting(byte)':
mms-arduino:249:13: error: 'turnLeft' was not declared in this scope
turnLeft();
mms-arduino:252:13: error: 'turnLeft' was not declared in this scope
turnLeft();
mms-arduino:256:13: error: 'turnLeft' was not declared in this scope
turnLeft();
mms-arduino:263:13: error: 'turnRight' was not declared in this scope
turnRight();
mms-arduino:266:13: error: 'turnLeft' was not declared in this scope
turnLeft();
mms-arduino:269:13: error: 'turnLeft' was not declared in this scope
turnLeft();
mms-arduino:277:13: error: 'turnLeft' was not declared in this scope
turnLeft();
mms-arduino:281:13: error: 'turnRight' was not declared in this scope
turnRight();
mms-arduino:284:13: error: 'turnLeft' was not declared in this scope
turnLeft();
mms-arduino:291:13: error: 'turnLeft' was not declared in this scope
turnLeft();
mms-arduino:294:13: error: 'turnLeft' was not declared in this scope
turnLeft();
mms-arduino:298:13: error: 'turnRight' was not declared in this scope
turnRight();
C:\Users\zoome\OneDrive\Desktop\maze solver\mms-arduino\mms-arduino.ino: In function 'void loop()':
mms-arduino:321:13: error: 'wallRight' was not declared in this scope
if (wallRight){
mms-arduino:357:13: error: 'wallLeft' was not declared in this scope
if (wallLeft){
C:\Users\zoome\OneDrive\Desktop\maze solver\mms-arduino\mms-arduino.ino:357:13: note: suggested alternative: 'walls'
if (wallLeft){
walls
mms-arduino:394:14: error: 'wallFront' was not declared in this scope
if (!wallFront()){
mms-arduino:395:13: error: 'moveForward' was not declared in this scope
moveForward();
C:\Users\zoome\OneDrive\Desktop\maze solver\mms-arduino\mms-arduino.ino: At global scope:
mms-arduino:460:1: error: expected declaration before '}' token
exit status 1
It is not detecting the built-in function, but when I tried running the sample given .ino file there while uploading it to arduino no such error was shown!
Exactly which sketch are you referring to ?
Please post it here, using code tags when you do
This is the given sample code on github from this link https://github.com/mackorone/mms-arduino/blob/master/mms-arduino.ino.
When i tried to upload to arduino it didn't give this error.
    log("Running...");
    setColor(0, 0, 'G');
    setText(0, 0, "abc");
    while (true) {
        if (!wallLeft()) {
            turnLeft();
        while (wallFront()) {
            turnRight();
        moveForward();
Also I am reposting my code here again with code tags so that it's easier for others to make changes to it
#include <stdio.h>
#include <stdlib.h>
#define Row 16
#define Column 16
struct Queue {
    int front;
    int rear;
    queue->front = -1;
    queue->rear = -1;
    return queue;
        return;
        queue->front = 0;
        queue->rear = 0;
        queue->rear++;
        return;
        queue->front = -1;
        queue->rear = -1;
        queue->front++;
        return -1;
        return;
byte grid[16][16];
byte start_x = 0;
byte start_y = 0;
//directions
//up = 0
//right = 1
//down = 2
//left = 3
byte min_val = 0;
byte direction = 0;
byte front_x = 0;
byte front_y = 15;
            else {
                walls[i][j][k] = 4;
            return 1;
    return 0;
//upper wall
//down wall
//right wall
//left wall
        direction = 1;
        direction = 2;
        direction = 3;
        direction = 0;
    return (min_val);
//orienting up
            turnLeft();
            turnLeft();
            turnLeft();
            turnLeft();
        orientation = 0;
//orienting right
            turnRight();
            turnLeft();
            turnLeft();
            turnLeft();
        orientation = 1;
//orienting down
            turnLeft();
            turnLeft();
            turnRight();
            turnLeft();
        orientation = 2;
//orienting left
            turnLeft();
            turnLeft();
            turnLeft();
            turnRight();
        orientation = 3;
     while (true){
    //        while (1){
        min_val = 0;
        direction = 0;
    //orienting up
        if (wallRight){
        if (wallLeft){
        if (!wallFront()){
            moveForward();
            start_y -= 1;
            start_x += 1;
            start_y += 1;
            start_x -= 1;
        else{
        //storing walls
                dequeue(queue);
                dequeue(queue);
