MicroView With a SD Datalogger??
Is it possible to use the Arduino SD Module with the MicroView due to the same pin outs not be available per the Uno set-up below?
CS------------------------------------PIN 4
SCK (CLOCK)-----------------------PIN 13
MISO--------------------------------PIN 12
MOSI--------------------------------PIN 11
VCC---------------------------------Voltage Supply (3.3 / 5 V)
GND---------------------------------Ground
Still have not nailed down a SD Module, would like a Micro SD if possible.
With SPI, SCK-MOSI-MISO are connected in parallel to all SPI devices, and each gets its own CS pin.
You have to work the connections to make the CSs unique per device.
CrossRoads:
After further research, I just found out that the MicroView is not set-up for these, the pins 11,12 & 13 are buried under the OLED display and while a mod might be possible it doesn't seem intuitive. I don't think it will give me what I desire, real time read out of RPM with secondary data logging.
