Trying to turn on a led time the on time then after X amount of time turn off led. just cant get it.
unsigned long interval = 5000;
unsigned long startTime;
int ledPin=13;
int myColor;
pinMode(ledPin,OUTPUT);
if(Serial.available()==0){
myColor=Serial.parseInt();
if (myColor==1){
digitalWrite(ledPin,HIGH);
startTime = millis();
Serial.println("led is on");
if (millis() - startTime >= interval){
digitalWrite(ledPin,LOW);
Firstly, please follow the advice on posting a programming question given in Read this before posting a programming question
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here
Here is your code posted in the preferred way
int ledPin = 13;
int myColor;
pinMode(ledPin, OUTPUT);
if (Serial.available() == 0)
myColor = Serial.parseInt();
if (myColor == 1)
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
As to your problem, if myColor becomes 1 due to serial input then its value will not change unless/until further serial input is received. If no further input is received then startTime will be reset to millis() each time through loop() so the comparison with interval will always fail
Another consideration is what you have the Line ending set to in the Serial monitor as if it set to anything apart from No line ending then there will be bytes in the Serial buffer after the number that you enter so Serial.available() will be greater than zero. What do you have it set to ?
if
if (myColor == 1)
is true every time through loop(), you are setting a new startTime everytime.
If it isn't true, you are never getting to the
part.
Hi Bilbo,
I'm not sure what you are trying do do. There is something with serial inside your code.
Please describe in normal words and detailed what the functionality shall be.
here is a demo code showing how to blink with millis()
unsigned long MyTimer;
unsigned long interval = 1000;
int ledPin = 13;
int LED_State = LOW;
unsigned long MyCounter = 0;
// function based on millis() for blinking
// a oneshot-timer needs additional logic
boolean TimePeriodIsOver (unsigned long &expireTime, unsigned long TimePeriod) {
if ( currentMillis - expireTime >= TimePeriod )
expireTime = currentMillis; // set new expireTime
return true; // more time than TimePeriod) has elapsed since last time if-condition was true
else return false; // not expired
Serial.println("Setup Start");
MyCounter++; // increment counter by one each time loop repeats
if (TimePeriodIsOver (MyTimer,interval) ) {
if (LED_State == LOW) {
LED_State = HIGH;
else {
LED_State = LOW;
digitalWrite (ledPin, LED_State);
// Demo for detailed serial output
Serial.print("digitalWrite ("); // print first part of fixed text
Serial.print(ledPin); // print content of constant "ledPin"
Serial.print(", "); // print fixed text
Serial.print(LED_State); // print content of variable "LED_State"
Serial.print(") MyCounter:" ); // print fixed text
Serial.print(MyCounter); // print value of variable MyCounter
Serial.println(); // new line
// the lines above print out
// digitalWrite (13, 0) MyCounter: nnnnnnn
// digitalWrite (13, 1) MyCounter: nnnnnnn ...
// nnnnnn is the rapidly increasing number of executed loops
// which shows the code outside the if-condition runs very fast
// and the if-condition gets true only once per defined value of interval
/* shortest possible code for blinking
digitalWrite (ledPin, !digitalRead(ledPin) );
read actual status of IO-Pin: digitalRead(ledPin)
invert status through not-operator the "!"
write the result with digitalWrite
all in all: digitalWrite (ledPin, !digitalRead(ledPin) );
you should always start from a very simple code.
Best a working example and then start from there changing the code in small steps
In this case a small testcode for receiving serial characters without anything else. Make the serial receiving work
and if it is working add the next part. Otherwise it stays unclear which part of the code has a bug.
best regards Stefan
I am trying to figure out the Millis function, so I can implement it on another program I'm working on. My objective is to get rid of the delay and replace with millis. I just can't wrap my head around it I guess thankyou for the help.
#include <Wire.h>
int flora;
int buttonPin;
long int bucketVal;
int ledState=1;
int ledPin=3;
int ledPin1=4;
int ledPin2=6;
int buttonOld;
int buttonNew=1;
int calm=0;
int calg=0;
int calb=0;
int pump;
long int Ml;
long int dt;
pinMode(buttonPin,INPUT);
digitalWrite(buttonPin,HIGH);
pinMode(ledPin1,OUTPUT);
pinMode(ledPin2,OUTPUT);
//Serial.println(Ml);
if(Serial.available()>0){
String Received = Serial.readString();
if(int(Received[0]) ==0x0C){
bucketVal=12;}
if(int(Received[0]) ==0x0B){
bucketVal=11;}
if(int(Received[0]) ==0x0A){
bucketVal=10;}
if(int(Received[0]) ==0x09){
bucketVal=9;}
if(int(Received[0]) ==0x08){
bucketVal=8;}
if(int(Received[0]) ==0x07){
bucketVal=7;}
if(int(Received[0]) ==0x06){
bucketVal=6;}
if(int(Received[0]) ==0x05){
bucketVal=5;}
if(int(Received[0]) ==0x04){
bucketVal=4;}
if(int(Received[0]) ==0x03){
bucketVal=3;}
if(int(Received[0]) ==0x02){
bucketVal=2;}
if(int(Received[0]) ==0x01){
bucketVal=1;}
if(int(Received[0]) == 0x17){
if (ledState==0){
ledState=1;
Ml=0;
pump=1;}
if(int(Received[0]) == 0x15){
if (ledState==0){
ledState=1;
Ml=0;
pump=4;}
if(int(Received[0]) == 0x1F){
if (ledState==0){
ledState=1;
Ml=0;
pump=7;}
if(int(Received[0]) == 0x29){
if (ledState==0){
ledState=1;
Ml=0;
pump=10;}
if(int(Received[0]) == 0){
digitalWrite(ledPin1,LOW);
digitalWrite(ledPin2,LOW);
ledState=0;
pump=0;
Ml=0;
Serial.print("t4.txt=\"NEWTS\"") ;
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print("n1.val=");
Serial.print(Ml);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print("n2.val=");
Serial.print(Ml);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print("n0.val=");
Serial.print(Ml);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
// Veg stage
if(pump==1){
// floraMicro pump
dt=5503.6*bucketVal;
Ml=dt/137.59;
Serial.print("t4.txt=\"MICRO\"") ;
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Serial.print(Ml);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
delay(dt);
pump=2;
// // floraGrow pump
if(pump==2){
Ml=dt/137.59;
Serial.print("t4.txt=\"GROW\"") ;
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
digitalWrite(ledPin1,HIGH);
Serial.print(Ml);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
delay(dt);
pump=3;
//floraBloom pump
if(pump==3){
dt=2751.8*bucketVal;
Ml=dt/137.59;
Serial.print("t4.txt=\"BLOOM\"") ;
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
digitalWrite(ledPin2,HIGH);
Serial.print(Ml);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
delay(dt);
pump=0;
ledState=0;
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Quite apart from using millis(), instead of this section of code
bucketVal=12;}
bucketVal=11;}
bucketVal=10;}
bucketVal=9;}
bucketVal=8;}
bucketVal=7;}
bucketVal=6;}
bucketVal=5;}
bucketVal=4;}
bucketVal=3;}
bucketVal=2;}
bucketVal=1;}
why not just
if (int(Received[0]) <= 0x0C && int(Received[0]) >= 1)
bucketval = int(Received[0]
even better, get rid of Strings, but maybe change just one thing at a time, but do take a look at Serial input basics - updated
UKHeliBob:
bucketval = int(Received[0]); // !
