I'm using this library because I haven't found other SSD1306 OLED libraries small enough to fit the very limited storage of STM32F030F4P6 (if you know other super lightweigth OLED lib alternative it is welcome).
miniOled library seems designed for 0.96" 128X64 OLED
However I want to use it on this 0.91" 128X32 OLED
And with this display if I try to print big numbers with Oled.printBigNumber method they are display correctly but if I try to print string with Oled.printString they are printed as unreadable pixel mess, maybe because the display resolution is too low.
I'm looking for a way to fix this
Checking the code the printBigNumber method uses this array to define numbers
const byte hugeFont [][72] = { // 18x24 inside a 24x32 cell.
{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x0f, 0x0f, 0x0f, 0x0f, 0x0f, 0x0f, 0x0f, 0x0f, 0x0f,
0x0f, 0x0f, 0x0f, 0x0f, 0x0f, 0x0f, 0x0f, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00}, // - minus
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0x0f, 0x0f, 0x0f,
0x0f, 0x00, 0x00, 0x00, 0x00}, // dot
{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
0xE0, 0xF0, 0xF0, 0x70, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x80, 0xE0, 0xF0, 0xFC, 0x7F, 0x3F, 0x0F, 0x03, 0x01, 0x00,
0x00, 0x00, 0x00, 0x00, 0xC0, 0xF0, 0xF8, 0xFE, 0x3F, 0x1F, 0x07,
0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x0F,
0x0F, 0x0F, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00}, // slash /
{0xC0, 0xE0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0,
0xF0, 0xF0, 0xF0, 0xF0, 0xE0, 0xC0, 0xFF, 0xFF, 0xFF, 0xFF, 0x01,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x80, 0xFF, 0xFF, 0xFF, 0xFF, 0x03, 0x07,
0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F,
0x0F, 0x0F, 0x0F, 0x07, 0x03}, // 0
{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0,
0xF0, 0xF0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00,
0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x07,
0x07, 0x03, 0x00, 0x00, 0x00}, // 1
{0xE0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0,
0xF0, 0xF0, 0xF0, 0xF0, 0xE0, 0x00, 0x81, 0xC1, 0xC0, 0xC0, 0xC0,
0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xE1, 0xFF, 0xFF, 0xFF,
0xFF, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x87, 0x03, 0x03, 0x03, 0x03,
0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x83, 0x81, 0x00, 0x07, 0x0F,
0x0F, 0x0F, 0x0F, 0x07, 0x00}, // 2
0x7F, 0x00, 0x81, 0x83, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03,
0x03, 0x03, 0x03, 0x87, 0xFF, 0xFF, 0xFF, 0xFE, 0x00, 0x07, 0x0F,
0x0F, 0x0F, 0x0F, 0x07, 0x00}, // 3
{0xE0, 0xF0, 0xF0, 0xF0, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x30, 0xF0, 0xF0, 0xF0, 0xE0, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xE0,
0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xE0, 0xFF, 0xFF, 0xFF,
0xFF, 0x00, 0x01, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03,
0x03, 0x03, 0x03, 0x07, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C,
0x0F, 0x0F, 0x0F, 0x07, 0x00}, // 4
0xF0, 0xF0, 0xF0, 0xF0, 0xE0, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xE1,
0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC1,
0x81, 0x00, 0x81, 0x83, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03,
0x03, 0x03, 0x03, 0x87, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x07, 0x0F,
0x0F, 0x0F, 0x0F, 0x07, 0x00}, // 5
0x81, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x87, 0x03, 0x03, 0x03, 0x03,
0x0F, 0x0F, 0x0F, 0x07, 0x00}, // 6
0xF0, 0xF0, 0xF0, 0xF0, 0xE0, 0x00, 0x01, 0x01, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xFF,
0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00,
0x0F, 0x0F, 0x0F, 0x07, 0x00}, // 7
0xF0, 0xF0, 0xF0, 0xF0, 0xE0, 0x00, 0x7F, 0xFF, 0xFF, 0xFF, 0xE1,
0x3F, 0x00, 0xFE, 0xFF, 0xFF, 0xFF, 0x87, 0x03, 0x03, 0x03, 0x03,
0x0F, 0x0F, 0x0F, 0x07, 0x00}, // 8
0x00, 0x0c, 0x0f, 0x0f, 0x0f, 0x0f, 0x0f, 0x0f, 0x0f, 0x0f, 0x0f,
0x0F, 0x0F, 0x0F, 0x07, 0x00}, // 9
0x00, 0x3C, 0x7E, 0x7E, 0x7E, 0x7E, 0x3C, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xF8, 0xF8,
0xF8, 0xF8, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01, 0x01, 0x01, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00} // ":"
And the printString method this other
const byte BasicFont[][5] = { // 5x8 in a 6x8 space.
{0x00,0x00,0x00,0x00,0x00},
{0x00,0x5F,0x00,0x00,0x00},
{0x00,0x07,0x00,0x07,0x00},
{0x14,0x7F,0x14,0x7F,0x14},
{0x24,0x2A,0x7F,0x2A,0x12},
{0x23,0x13,0x08,0x64,0x62},
{0x36,0x49,0x55,0x22,0x50},
{0x00,0x05,0x03,0x00,0x00},
{0x1C,0x22,0x41,0x00,0x00},
{0x41,0x22,0x1C,0x00,0x00},
{0x08,0x2A,0x1C,0x2A,0x08},
{0x08,0x08,0x3E,0x08,0x08},
{0xA0,0x60,0x00,0x00,0x00},
{0x08,0x08,0x08,0x08,0x08},
{0x60,0x60,0x00,0x00,0x00},
{0x20,0x10,0x08,0x04,0x02},
{0x3E,0x51,0x49,0x45,0x3E},
{0x00,0x42,0x7F,0x40,0x00},
{0x62,0x51,0x49,0x49,0x46},
{0x22,0x41,0x49,0x49,0x36},
{0x18,0x14,0x12,0x7F,0x10},
{0x27,0x45,0x45,0x45,0x39},
{0x3C,0x4A,0x49,0x49,0x30},
{0x01,0x71,0x09,0x05,0x03},
{0x36,0x49,0x49,0x49,0x36},
{0x06,0x49,0x49,0x29,0x1E},
{0x00,0x36,0x36,0x00,0x00},
{0x00,0xAC,0x6C,0x00,0x00},
{0x08,0x14,0x22,0x41,0x00},
{0x14,0x14,0x14,0x14,0x14},
{0x41,0x22,0x14,0x08,0x00},
{0x02,0x01,0x51,0x09,0x06},
{0x32,0x49,0x79,0x41,0x3E},
{0x7E,0x09,0x09,0x09,0x7E},
{0x7F,0x49,0x49,0x49,0x36},
{0x3E,0x41,0x41,0x41,0x22},
{0x7F,0x41,0x41,0x22,0x1C},
{0x7F,0x49,0x49,0x49,0x41},
{0x7F,0x09,0x09,0x09,0x01},
{0x3E,0x41,0x41,0x51,0x72},
{0x7F,0x08,0x08,0x08,0x7F},
{0x41,0x7F,0x41,0x00,0x00},
{0x20,0x40,0x41,0x3F,0x01},
{0x7F,0x08,0x14,0x22,0x41},
{0x7F,0x40,0x40,0x40,0x40},
{0x7F,0x02,0x0C,0x02,0x7F},
{0x7F,0x04,0x08,0x10,0x7F},
{0x3E,0x41,0x41,0x41,0x3E},
{0x7F,0x09,0x09,0x09,0x06},
{0x3E,0x41,0x51,0x21,0x5E},
{0x7F,0x09,0x19,0x29,0x46},
{0x26,0x49,0x49,0x49,0x32},
{0x01,0x01,0x7F,0x01,0x01},
{0x3F,0x40,0x40,0x40,0x3F},
{0x1F,0x20,0x40,0x20,0x1F},
{0x3F,0x40,0x38,0x40,0x3F},
{0x63,0x14,0x08,0x14,0x63},
{0x03,0x04,0x78,0x04,0x03},
{0x61,0x51,0x49,0x45,0x43},
{0x7F,0x41,0x41,0x00,0x00},
{0x02,0x04,0x08,0x10,0x20},
{0x41,0x41,0x7F,0x00,0x00},
{0x04,0x02,0x01,0x02,0x04},
{0x80,0x80,0x80,0x80,0x80},
{0x01,0x02,0x04,0x00,0x00},
{0x20,0x54,0x54,0x54,0x78},
{0x7F,0x48,0x44,0x44,0x38},
{0x38,0x44,0x44,0x28,0x00},
{0x38,0x44,0x44,0x48,0x7F},
{0x38,0x54,0x54,0x54,0x18},
{0x08,0x7E,0x09,0x02,0x00},
{0x18,0xA4,0xA4,0xA4,0x7C},
{0x7F,0x08,0x04,0x04,0x78},
{0x00,0x7D,0x00,0x00,0x00},
{0x80,0x84,0x7D,0x00,0x00},
{0x7F,0x10,0x28,0x44,0x00},
{0x41,0x7F,0x40,0x00,0x00},
{0x7C,0x04,0x18,0x04,0x78},
{0x7C,0x08,0x04,0x7C,0x00},
{0x38,0x44,0x44,0x38,0x00},
{0xFC,0x24,0x24,0x18,0x00},
{0x18,0x24,0x24,0xFC,0x00},
{0x00,0x7C,0x08,0x04,0x00},
{0x48,0x54,0x54,0x24,0x00},
{0x04,0x7F,0x44,0x00,0x00},
{0x3C,0x40,0x40,0x7C,0x00},
{0x1C,0x20,0x40,0x20,0x1C},
{0x3C,0x40,0x30,0x40,0x3C},
{0x44,0x28,0x10,0x28,0x44},
{0x1C,0xA0,0xA0,0x7C,0x00},
{0x44,0x64,0x54,0x4C,0x44},
{0x08,0x36,0x41,0x00,0x00},
{0x00,0x7F,0x00,0x00,0x00},
{0x41,0x36,0x08,0x00,0x00},
{0x02,0x01,0x01,0x02,0x01},
{0x02,0x05,0x05,0x02,0x00}
But I don't know how to replace it with something suitable for this display.
Any help is very appreciated.
