MakerFocus OLED Display Module I2C 128X64 1.3 Inch Display Module SSD1106 Only half working
I've been unable to get either of these displays working. I have the correct address, added an external 5v power supply, and have tested with 2 displays and 2 arduino boards. It plays animations or text in the upper half but shows this issue on the rest. This also happens with both examples provided (64 and 32).
Can anyone suggest a solution, or has had the same issue?
  • Always show us a good schematic of your proposed circuit.
    Show us good images of your ‘actual’ wiring.
    Give links to components.
  • In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
    Use the < CODE / > icon from the ‘posting menu’ to attach the copied sketch.
  • What does this sketch do ?
//  OLED_Counter.ino
//  LarryD
//  Version   YY/MM/DD     Comments
//  1.00      22/04/21     Running code
//https://lastminuteengineers.com/oled-display-arduino-tutorial/
#include <Wire.h>
//#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH        128   //OLED display width,  in pixels
#define SCREEN_HEIGHT       64   //OLED display height, in pixels
//SSD1306 display
//size 1 is 5X7   pixels therefore, 6X8   to acount for spacing,  21 characters per line
//size 2 is 10X14 pixels therefore, 11X15 to account for spacing, 10 characters per line
//size 4 is 20X28 pixels therefore, 21X29 to account for spacing,  5 characters per line
//Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
unsigned long counter     = 0;
//                                      s e t u p ( )
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C))
    Serial.println(F("SSD1306 allocation failed"));
    for (;;);
  display.clearDisplay();
  //display.setTextColor(textColor, backgroundColor);
  display.setTextColor(WHITE, BLACK);
} //END of   setup()
//                                       l o o p ( )
  //clear SSD1306 display
  display.setTextSize(1);
  display.setCursor(0, 0);
  //Size 1 line is  000000000111111111122
  //21 characters   123456789012345678901
  //Example         ..OLED Counter Demo..
  display.print("  OLED Counter Demo  ");
  //display.setCursor(0,9);
  //display.print ("ABCDEFGHIJKLMNOPQRSTU");
  display.setTextSize(2);
  //2 = current text size, 16 is the pixel row we want to postion to
  display.setCursor(centering(counter, 2), 16);
  //Size 2 line     0000000001
  //10 characters   1234567890
  //Example           100000
  display.print(counter++);
  //degree symbol
  //using CP437 ASCII
  //display.cp437(true);
  //display.write(248);
  //  display.setTextSize(2);
  //  display.setCursor(0,16);
  //  display.setCursor(0,32);
  //  //temperature
  //  //Size 2 line is  0000000001
  //  //10 characters   1234567890
  //  //Example         ABCDEFGHIJ
  //  display.print("ABCDEFGHIJ");
  display.display();
  delay(100);
} //END of   loop()
//                                 c o u n t D i g i t s ( )
//return the number of digits in a number
byte countDigits(int num)
  byte count = 0;
  while (num)
    num = num / 10;
    count++;
  return count;
} //END of   countDigits()
//                                    g e t D i g i t ( )
//return the selected digit
byte getDigit(unsigned int number, int digit)
  for (int i = 0; i < digit - 1; i++)
    number = number / 10;
  return number % 10;
} //END of   getDigit()
//                                   c e n t e r i n g ( )
//return the position to print the MSD
byte centering(unsigned long number, byte textSize)
  byte count = 0;
  byte charaterCellWidth = 0;
  //a basic character is 5X7, we must scale for this text size
  charaterCellWidth = (5 * textSize) + 1;
  //number of digits in our number
  while (number)
    count++;
  //center location where the MSD character will be displayed
  return (SCREEN_WIDTH / 2 - (charaterCellWidth * count / 2));
} //END of   centering()
The text seems like it's scrolling past fast on the top section but the rest is still the same.
What is the part number of the OLED ?
JMD 1.3A I think.
  • Let's try one more time.
Try this sketch:
  This is an example for our Monochrome OLEDs based on SH110X drivers
  This example is for a 128x64 size display using I2C to communicate
  3 pins are required to interface (2 I2C and one reset)
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada  for Adafruit Industries.
  BSD license, check license.txt for more information
  All text above, and the splash screen must be included in any redistribution
  i2c SH1106 modified by Rupert Hirst  12/09/21
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_SH110X.h>
/* Uncomment the initialize the I2C address , uncomment only one, If you get a totally blank screen try the other*/
#define i2c_Address 0x78   //initialize with the I2C addr 0x3C Typically eBay OLED's
//#define i2c_Address 0x3c //initialize with the I2C addr 0x3C Typically eBay OLED's
//#define i2c_Address 0x3d //initialize with the I2C addr 0x3D Typically Adafruit OLED's
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1   //   QT-PY / XIAO
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
static const unsigned char PROGMEM logo16_glcd_bmp[] =
{ B00000000, B11000000,
  B00000001, B11000000,
  B00000011, B11100000,
  B11110011, B11100000,
  B11111110, B11111000,
  B01111110, B11111111,
  B00110011, B10011111,
  B00011111, B11111100,
  B00001101, B01110000,
  B00011011, B10100000,
  B00111111, B11100000,
  B00111111, B11110000,
  B01111100, B11110000,
  B01110000, B01110000,
  B00000000, B00110000
void setup()   {
  // Show image buffer on the display hardware.
  // Since the buffer is intialized with an Adafruit splashscreen
  // internally, this will display the splashscreen.
  delay(250); // wait for the OLED to power up
  display.begin(i2c_Address, true); // Address 0x3C default
 //display.setContrast (0); // dim display
  display.display();
  delay(2000);
  // Clear the buffer.
  // draw a single pixel
  display.drawPixel(10, 10, SH110X_WHITE);
  // Show the display buffer on the hardware.
  // NOTE: You _must_ call display after making any drawing commands
  // to make them visible on the display hardware!
  display.display();
  delay(2000);
  // draw many lines
  testdrawline();
  display.display();
  delay(2000);
  // draw rectangles
  testdrawrect();
  display.display();
  delay(2000);
  // draw multiple rectangles
  testfillrect();
  display.display();
  delay(2000);
  // draw mulitple circles
  testdrawcircle();
  display.display();
  delay(2000);
  // draw a SH110X_WHITE circle, 10 pixel radius
  display.fillCircle(display.width() / 2, display.height() / 2, 10, SH110X_WHITE);
  display.display();
  delay(2000);
  testdrawroundrect();
  delay(2000);
  testfillroundrect();
  delay(2000);
  testdrawtriangle();
  delay(2000);
  testfilltriangle();
  delay(2000);
  // draw the first ~12 characters in the font
  testdrawchar();
  display.display();
  delay(2000);
  // text display tests
  display.setTextColor(SH110X_WHITE);
  display.println("Failure is always an option");
  display.setTextColor(SH110X_BLACK, SH110X_WHITE); // 'inverted' text
  display.println(3.141592);
  display.print("0x"); display.println(0xDEADBEEF, HEX);
  display.display();
  delay(2000);
  // miniature bitmap display
  display.drawBitmap(30, 16,  logo16_glcd_bmp, 16, 16, 1);
  display.display();
  delay(1);
  // invert the display
  display.invertDisplay(true);
  display.invertDisplay(false);
  // draw a bitmap icon and 'animate' movement
  testdrawbitmap(logo16_glcd_bmp, LOGO16_GLCD_HEIGHT, LOGO16_GLCD_WIDTH);
void testdrawbitmap(const uint8_t *bitmap, uint8_t w, uint8_t h) {
  uint8_t icons[NUMFLAKES][3];
  // initialize
  for (uint8_t f = 0; f < NUMFLAKES; f++) {
    icons[f][XPOS] = random(display.width());
    icons[f][YPOS] = 0;
    icons[f][DELTAY] = random(5) + 1;
    Serial.print("x: ");
    Serial.print(icons[f][XPOS], DEC);
    Serial.print(" y: ");
    Serial.print(icons[f][YPOS], DEC);
    Serial.print(" dy: ");
    Serial.println(icons[f][DELTAY], DEC);
  while (1) {
    // draw each icon
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, SH110X_WHITE);
    display.display();
    delay(200);
    // then erase it + move it
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, SH110X_BLACK);
      // move it
      icons[f][YPOS] += icons[f][DELTAY];
      // if its gone, reinit
      if (icons[f][YPOS] > display.height()) {
        icons[f][YPOS] = 0;
void testdrawchar(void) {
  for (uint8_t i = 0; i < 168; i++) {
    if (i == '\n') continue;
    display.write(i);
    if ((i > 0) && (i % 21 == 0))
      display.println();
  display.display();
  delay(1);
void testdrawcircle(void) {
  for (int16_t i = 0; i < display.height(); i += 2) {
    display.drawCircle(display.width() / 2, display.height() / 2, i, SH110X_WHITE);
    display.display();
    delay(1);
void testfillrect(void) {
  uint8_t color = 1;
  for (int16_t i = 0; i < display.height() / 2; i += 3) {
    // alternate colors
    display.fillRect(i, i, display.width() - i * 2, display.height() - i * 2, color % 2);
    display.display();
    delay(1);
    color++;
void testdrawtriangle(void) {
  for (int16_t i = 0; i < min(display.width(), display.height()) / 2; i += 5) {
    display.drawTriangle(display.width() / 2, display.height() / 2 - i,
                         display.width() / 2 - i, display.height() / 2 + i,
                         display.width() / 2 + i, display.height() / 2 + i, SH110X_WHITE);
    display.display();
    delay(1);
void testfilltriangle(void) {
  uint8_t color = SH110X_WHITE;
  for (int16_t i = min(display.width(), display.height()) / 2; i > 0; i -= 5) {
    display.fillTriangle(display.width() / 2, display.height() / 2 - i,
    if (color == SH110X_WHITE) color = SH110X_BLACK;
    else color = SH110X_WHITE;
    display.display();
    delay(1);
void testdrawroundrect(void) {
  for (int16_t i = 0; i < display.height() / 2 - 2; i += 2) {
    display.drawRoundRect(i, i, display.width() - 2 * i, display.height() - 2 * i, display.height() / 4, SH110X_WHITE);
    display.display();
    delay(1);
void testfillroundrect(void) {
    display.fillRoundRect(i, i, display.width() - 2 * i, display.height() - 2 * i, display.height() / 4, color);
    display.display();
    delay(1);
void testdrawrect(void) {
  for (int16_t i = 0; i < display.height() / 2; i += 2) {
    display.drawRect(i, i, display.width() - 2 * i, display.height() - 2 * i, SH110X_WHITE);
    display.display();
    delay(1);
void testdrawline() {
  for (int16_t i = 0; i < display.width(); i += 4) {
    display.drawLine(0, 0, i, display.height() - 1, SH110X_WHITE);
    display.display();
    delay(1);
  for (int16_t i = 0; i < display.height(); i += 4) {
    display.drawLine(0, 0, display.width() - 1, i, SH110X_WHITE);
    display.display();
    delay(1);
  delay(250);
    display.drawLine(0, display.height() - 1, i, 0, SH110X_WHITE);
    display.display();
    delay(1);
  for (int16_t i = display.height() - 1; i >= 0; i -= 4) {
    display.drawLine(0, display.height() - 1, display.width() - 1, i, SH110X_WHITE);
    display.display();
    delay(1);
  delay(250);
  for (int16_t i = display.width() - 1; i >= 0; i -= 4) {
    display.drawLine(display.width() - 1, display.height() - 1, i, 0, SH110X_WHITE);
    display.display();
    delay(1);
    display.drawLine(display.width() - 1, display.height() - 1, 0, i, SH110X_WHITE);
    display.display();
    delay(1);
  delay(250);
    display.drawLine(display.width() - 1, 0, 0, i, SH110X_WHITE);
    display.display();
    delay(1);
    display.drawLine(display.width() - 1, 0, i, display.height() - 1, SH110X_WHITE);
    display.display();
    delay(1);
  delay(250);
That Worked! Thanks so much you've saved so much time. Appricate your time.
