MKR 1010 NINA WIFI Firmware Update Issue
Hello !
I currently have a MKR 1010 running on the NINA 1.3.0.
I run the Check Firmware Version Script and i receive the output.
16:00:04.306 -> WiFiNINA firmware check.
16:00:04.306 ->
16:00:05.060 -> Firmware version installed: 1.3.0
16:00:05.060 -> Latest firmware version available : 1.4.3
16:00:05.060 ->
16:00:05.060 -> Check result: NOT PASSED
16:00:05.060 ->  - The firmware version on the module does not match the
16:00:05.060 ->    version required by the library, you may experience
16:00:05.060 ->    issues or failures.
In the MKR firmware updater i am not given the option to update to any other firmware other then 1.3.0
I am able to download the latest NINA firmware and place it into the folder directory with the other NINA firmware but it just not give me to option update to it.
I would appreciate any help on updating thank you.
I ran into this, the Arduino IDE 1.8.13 that is the latest product version won't go above 1.3, but if you install the latest hourly build (look lower on the IDE download page) that will let you get to 1.4.1 when I did it, maybe now 1.4.3.
