MKR wifi 1010 bootloader flashing issue
Hi! I am currently trying to flash mkr wifi 1010 board because I suspect it being stuck. I tried connecting it to 3 different computers, 7 different cords, other usb devices and my mkr zero is being visible on computer but wifi 1010 is not. Also after doublepressing reset button in various different ways nothing happens, led is not blinking. I'm just a mobile developer who dose not understand that much in this and trying out new hobby and I would like to save this board and some money with it.
I began following MKR wifi 1010 bootloader - #2 by pert instructions but I'm stuck. After uploading code on zero and connected pins to wifi 1010 when zero is connected to computer it dose not see it. If I disconnect gnd or vcc it immediately appears in device manager and ide can see it. Also i get some sort of error code when loading flash_MKR_bootloaders.ino
In file included from C:\Users\pavel\OneDrive\Documents\Arduino\libraries\Adafruit_DAP_library/Adafruit_DAP.h:269:0,
                 from C:\Users\pavel\AppData\Local\Temp\.arduinoIDE-unsaved202409-6504-11ip87y.d8rt\flash_MKR_bootloaders\flash_MKR_bootloaders.ino:1:
C:\Users\pavel\OneDrive\Documents\Arduino\libraries\Adafruit_DAP_library/Adafruit_DAP_SAM.h:166:40: note: offset of packed bit-field 'Adafruit_DAP_SAMx5::<unnamed union>::<unnamed struct>::BOD33_Level' has changed in GCC 4.4
     struct __attribute__((__packed__)) {
C:\Users\pavel\OneDrive\Documents\Arduino\libraries\Adafruit_DAP_library/Adafruit_DAP_SAM.h:166:40: note: offset of packed bit-field 'Adafruit_DAP_SAMx5::<unnamed union>::<unnamed struct>::<anonymous>' has changed in GCC 4.4
C:\Users\pavel\OneDrive\Documents\Arduino\libraries\Adafruit_DAP_library/Adafruit_DAP_SAM.h:166:40: note: offset of packed bit-field 'Adafruit_DAP_SAMx5::<unnamed union>::<unnamed struct>::WDT_Window' has changed in GCC 4.4
In file included from C:\Users\pavel\OneDrive\Documents\Arduino\libraries\Adafruit_DAP_library\Adafruit_DAP.h:269:0,
                 from C:\Users\pavel\OneDrive\Documents\Arduino\libraries\Adafruit_DAP_library\Adafruit_DAP_STM32.cpp:33:
C:\Users\pavel\OneDrive\Documents\Arduino\libraries\Adafruit_DAP_library\Adafruit_DAP_SAM.h:166:40: note: offset of packed bit-field 'Adafruit_DAP_SAMx5::<unnamed union>::<unnamed struct>::BOD33_Level' has changed in GCC 4.4
C:\Users\pavel\OneDrive\Documents\Arduino\libraries\Adafruit_DAP_library\Adafruit_DAP_SAM.h:166:40: note: offset of packed bit-field 'Adafruit_DAP_SAMx5::<unnamed union>::<unnamed struct>::<anonymous>' has changed in GCC 4.4
C:\Users\pavel\OneDrive\Documents\Arduino\libraries\Adafruit_DAP_library\Adafruit_DAP_SAM.h:166:40: note: offset of packed bit-field 'Adafruit_DAP_SAMx5::<unnamed union>::<unnamed struct>::WDT_Window' has changed in GCC 4.4
                 from C:\Users\pavel\OneDrive\Documents\Arduino\libraries\Adafruit_DAP_library\Adafruit_DAP_SAMx5.cpp:33:
                 from C:\Users\pavel\OneDrive\Documents\Arduino\libraries\Adafruit_DAP_library\Adafruit_DAP_nRF5x.cpp:33:
                 from C:\Users\pavel\OneDrive\Documents\Arduino\libraries\Adafruit_DAP_library\Adafruit_DAP_SAM.cpp:33:
                 from C:\Users\pavel\OneDrive\Documents\Arduino\libraries\Adafruit_DAP_library\Adafruit_DAP.cpp:33:
Sketch uses 108244 bytes (41%) of program storage space. Maximum is 262144 bytes.
Global variables use 3952 bytes (12%) of dynamic memory, leaving 28816 bytes for local variables. Maximum is 32768 bytes.
Atmel SMART device 0x10010005 found
Device       : ATSAMD21G18A
Chip ID      : 10010005
Version      : v2.0 [Arduino:XYZ] Dec 20 2016 15:36:46
Address      : 8192
Pages        : 3968
Page Size    : 64 bytes
Total Size   : 248KB
Planes       : 1
Lock Regions : 16
Locked       : none
Security     : false
Boot Flash   : true
BOD          : false
BOR          : false
Arduino      : FAST_CHIP_ERASE
Arduino      : FAST_MULTI_PAGE_WRITE
Arduino      : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
done in 0.822 seconds
Write 108252 bytes to flash (1692 pages)
[=                             ] 3% (64/1692 pages)
[==                            ] 7% (128/1692 pages)
[===                           ] 11% (192/1692 pages)
[====                          ] 15% (256/1692 pages)
[=====                         ] 18% (320/1692 pages)
[======                        ] 22% (384/1692 pages)
[=======                       ] 26% (448/1692 pages)
[=========                     ] 30% (512/1692 pages)
[==========                    ] 34% (576/1692 pages)
[===========                   ] 37% (640/1692 pages)
[============                  ] 41% (704/1692 pages)
[=============                 ] 45% (768/1692 pages)
[==============                ] 49% (832/1692 pages)
[===============               ] 52% (896/1692 pages)
[=================             ] 56% (960/1692 pages)
[==================            ] 60% (1024/1692 pages)
[===================           ] 64% (1088/1692 pages)
[====================          ] 68% (1152/1692 pages)
[=====================         ] 71% (1216/1692 pages)
[======================        ] 75% (1280/1692 pages)
[=======================       ] 79% (1344/1692 pages)
[========================      ] 83% (1408/1692 pages)
[==========================    ] 86% (1472/1692 pages)
[===========================   ] 90% (1536/1692 pages)
[============================  ] 94% (1600/1692 pages)
[============================= ] 98% (1664/1692 pages)
[==============================] 100% (1692/1692 pages)
done in 0.828 seconds
Verify 108252 bytes of flash with checksum.
Verify successful
done in 0.088 seconds
CPU reset.
edit: I'm using 2.2.1 IDE and also tried it on 1.8.1 IDE both don't work.
Wifi 1010 did work for couple months and after trying to control stepper motor with driver it lagged and now its just 1 green led on and thats it.
double rest didn't help to activate the bootloader?
No, I have done it in the past couple times and it have worked before. This time it did not do anything.
