This is my first foray into Arduino modules and I am trying to set up a MKR Wifi 1010 + MKR Env Shield as a proof of concept for monitoring environmental conditions in growth chambers and greenhouses.
I installed Arduino IDE and respective SAMD drivers for the MKR board but my computer will not recognize the board when plugged into any USB. So far I have tried:
Installing Arduino IDE from the Arduino site by downloading the installer.
I uninstalled that version and reinstalled Arduino IDE via the Microsoft store.
I have swapped out USB-MicroUSB cables and tried various USB ports on my laptop (additionally I checked each port that I tried for responsiveness in the device manager by plugging in a mouse to each one.)
I went back to the SAMD drivers and installed various versions of it to see if one of the older versions might work for initial setup.
Per every forum I have read on this topic I have tried the old double tap of the reset button at every step of this process to ensure there were no changes at any point.
At every step I see all three lights on the board "On", "L", and occasionally "CHRG".
Do I at this point need to consider burning the bootloader onto the board again?
The same thing happened to me and I was about to give up until I decided to just cycle through all of the USB cables in my house. Eventually I found one cable that will successfully connect the MKR 1010 to my computer.
Even other known-good cables that successfully connect other devices failed to work on the MKR wifi 1010; but for some reason this braided cable (likely the most expensive one that I own) works 100% of the time.
Thank you for your prompt replies with helpful tips! This simple exchange has made me very excited to become an active member of the Arduino community!
I had tried the troubleshooting steps that were suggested by the Arduino team as I have seen them in other forums and I was in the process of ordering various microUSB cables, as it turns out not all cables are created equal and one of the new ones was able to establish a connection with the module.
