MKR1000 cannt find its IP adress
I am newbie in this arduino world. Just got my MKR1000 and try to get it started. I downloaded a sample file (WiFi101-ConnectWithWPA) and changed my Wifi user name and password, uploaded it, and everything looks OK now. But when I open Serial Monitor, I can only see "Attempting to connect to Network named:XXX" again and again. I tried some other files and got same result. Switched to different computer and different router ends up same thing. How to solve this problem? Please help.
Thanks!
can you upload the code. Without code it would be hard to understand your problem.
rgrd,
Ehsan
This example connects to an unencrypted WiFi network.
Then it prints the MAC address of the WiFi shield,
the IP address obtained, and other network details.
Circuit:
  • WiFi shield attached
created 13 July 2010
by dlf (Metodo2 srl)
modified 31 May 2012
by Tom Igoe
#include <SPI.h>
#include <WiFi101.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = "myssid"; // your network SSID (name)
char pass[] = "mypassword"; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS; // the WiFi radio's status
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
// attempt to connect to WiFi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the data:
Serial.print("You're connected to the network");
printCurrentNet();
printWiFiData();
// check the network connection once every 10 seconds:
delay(10000);
printCurrentNet();
void printWiFiData() {
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
Serial.println(ip);
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
printMacAddress(mac);
void printCurrentNet() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the MAC address of the router you're attached to:
byte bssid[6];
WiFi.BSSID(bssid);
Serial.print("BSSID: ");
printMacAddress(bssid);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.println(rssi);
// print the encryption type:
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type:");
Serial.println(encryption, HEX);
void printMacAddress(byte mac[]) {
for (int i = 5; i >= 0; i--) {
if (mac < 16) {
  • Serial.print("0");*
    _ Serial.print(mac*, HEX);_
    _
    if (i > 0) {_
    _
    Serial.print(":");_
    _
    }_
    _
    }_
    _
    Serial.println();_
    _
    }*_
jhou2020:
Thanks!
Is it the driver issue? You need to look at Device manager to check whether is driver is OK, see the tutorial here:
https://www.arduino.cc/en/Guide/MKR1000
If it's the router problem, did MKR1000 store your previous WiFi username and password? If you forgot them, look here Default Router Username and Password List - 192.168.0.1 Router Login.
Or try to upgrade the firmware.
@jhou2020
You were provided with useful links but have failed to use them to your advantage.
Please take the next 24 hours to use them.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
