Accepted wisdom says if you understand code then use it, If you cant understand code don't use it. I have found code which I need on Github and acknowledge the original author. It is at the limit of my understanding so I have commented the code more fully to show my understanding of each line. If I have misunderstood the code can you please point out my errors and suggest where I might find information to better understand.
* CODE by Johnathan Martin a.k.a the_jmart
* By using the TCA9548A I2C Multiplexer Breakout you can read
* four VL53L0X Time-of-Flight range sensors at the same time over
* one I2C address. This code is written specific for the devices
* used.
* TCA9548 I2CScanner.pde -- I2C bus scanner for Arduino
* Based on code c. 2009, Tod E. Kurt, http://todbot.com/blog/
#include "Wire.h"
/*extern "C" { ***MKR1500 doesn't need/want this
#include "utility/twi.h" // from Wire library, so we can do bus scanning
#include "Adafruit_VL53L0X.h"
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
#define TCAADDR 0x70
* Adafruit "suggest using this little helper to help you select the port" the next 7 lines
void tcaselect(uint8_t i) { //An 8 bit unsigned integer, i is passed to a void function
if (i > 7) return; //if (i>7) terminate the (void)function without returning anything
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i); //left shift 1 by i places ==i.e. put i zeros to the right of it, then write that to the TCA9548A on I2C
Wire.endTransmission();
// standard Arduino setup()
while (!Serial);
Wire.begin();
Serial.print("Start.");
tcaselect(0); //call the function tcaselect and pass the function 0 so i = 0, so 1 is left shifted 0 places so 0b00000001 gets sent to the TCA9548A, opening channel 0
if (!lox.begin()) { //if sensor doesn't respond
Serial.println(F("Failed to boot VL53L0X")); //serial report the failure
while(1); //enter infinite loop and do nothing
tcaselect(1); //call the function tcaselect and pass the function 1 so i = 1, so 1 is left shifted 1 places so 0b00000010 gets sent to the TCA9548A, opening channel 1
if (!lox.begin()) {
while(1);
tcaselect(2); //call the function tcaselect and pass the function 2 so i = 2, so 1 is left shifted 2 places so 0b00000100 gets sent to the TCA9548A, opening channel 2
if (!lox.begin()) {
while(1);
tcaselect(3); //call the function tcaselect and pass the function 3 so i = 3, so 1 is left shifted 3 places so 0b00001000 gets sent to the TCA9548A, opening channel 3
if (!lox.begin()) {
while(1);
/* only using using channels 0-3
tcaselect(7);
if (!lox.begin()) {
while(1);
Serial.println(" End setup");
delay(2000);
VL53L0X_RangingMeasurementData_t measure;
lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
if (measure.RangeStatus != 4) { // phase failures have incorrect data
Serial.print("L0: "); Serial.print(measure.RangeMilliMeter);Serial.print(" "); //print that sensor 0 responds xxxmm ,
Serial.print("L0: "); Serial.print("OOR"); Serial.print(" "); // //print that sensor 0 is Out Of Range ,
tcaselect(1);
Serial.print("L1: "); Serial.print(measure.RangeMilliMeter);Serial.print(" ");
Serial.print("L1: "); Serial.print("OOR");Serial.print(" ");
tcaselect(2);
Serial.print("L2: "); Serial.print(measure.RangeMilliMeter);Serial.print(" ");
Serial.print("L2: "); Serial.print("OOR");Serial.print(" ");
tcaselect(7);
Serial.print("L3: "); Serial.print(measure.RangeMilliMeter);Serial.print(" ");
Serial.print("L3: "); Serial.print("OOR");Serial.print(" ");
Serial.println("");
delay(20);
