I followed this: ML8511 UV Sensor Hookup Guide - SparkFun Learn tutorial exactly and the output voltage is fluctuating around 3V, even in the shade or directly exposed to sunlight, it just stays the same.
I hooked it up to the Arduino R4 wifi board.
Are there any possible solutions to this? Is the sensor faulty? (i used the exact sensor from the tutorial)
EDIT: I saw a post with a very similar issue to mine, and the only response was of someone saying that you need to solder the pins to the sensor. Is that true? I just used a breadboard like in the tutorial.
