Sorry to insist but today i tested again the problem.
So instead of Arduino Nano, i used :
Regular Arduino MEGA
example software "Modbus RTU Server Kitchen Sink" with just adding few lines to measure the time of the Pool() method and sent the time to Serial2 for logging purpose
Arduino mega is connected without RS485, direct on a RS232 TTL to a computer.
Arduino Master RTU is a Computer software used : QModMaster
Modbus adress is 42.
When sending to device 42
[RTU]>Tx > 13:36:22:648 - 2A 03 00 00 00 01 82 11
[RTU]>Rx > 13:36:22:673 - 2A 03 02 00 00 9C 42
Everything fine, pool method using 15ms of time.
When sending to device 41 ( who do not exist )
[RTU]>Tx > 13:36:32:289 - 29 03 00 00 00 01 82 22
Nobody reply, so normal but the "pool() method on the arduino adr42 take 7ms and then 500ms.
So this 500ms block the rest of the program in the arduino.
So there is a problem in this library in general.
That's so strange that nobody had this issue before, it is so simple to encounter.
Hope someone can give me directions because i'm not good enough to modify library
This sketch creates a Modbus RTU Server and demostrates
how to use various Modbus Server APIs.
Circuit:
- MKR board
- MKR 485 shield
- ISO GND connected to GND of the Modbus RTU server
- Y connected to A/Y of the Modbus RTU client
- Z connected to B/Z of the Modbus RTU client
- Jumper positions
- FULL set to OFF
- Z \/\/ Y set to OFF
created 18 July 2018
by Sandeep Mistry
#include <ArduinoRS485.h> // ArduinoModbus depends on the ArduinoRS485 library
#include <ArduinoModbus.h>
unsigned int cycle;
const int numCoils = 10;
const int numDiscreteInputs = 10;
const int numHoldingRegisters = 10;
const int numInputRegisters = 10;
while (!Serial);
Serial2.begin(115200);
Serial2.println("Modbus RTU Server Kitchen Sink");
// start the Modbus RTU server, with (slave) id 42
if (!ModbusRTUServer.begin(42, 9600)) {
Serial2.println("Failed to start Modbus RTU Server!");
while (1);
// configure coils at address 0x00
ModbusRTUServer.configureCoils(0x00, numCoils);
// configure discrete inputs at address 0x00
ModbusRTUServer.configureDiscreteInputs(0x00, numDiscreteInputs);
// configure holding registers at address 0x00
ModbusRTUServer.configureHoldingRegisters(0x00, numHoldingRegisters);
// configure input registers at address 0x00
ModbusRTUServer.configureInputRegisters(0x00, numInputRegisters);
cycle = millis();
// Pool for modbus requests
ModbusRTUServer.poll();
cycle = millis() - cycle ;
if ( cycle > 2 )
Serial2.print("ms: ");
Serial2.println(cycle);
// map the coil values to the discrete input values
for (int i = 0; i < numCoils; i++) {
int coilValue = ModbusRTUServer.coilRead(i);
ModbusRTUServer.discreteInputWrite(i, coilValue);
// map the holiding register values to the input register values
for (int i = 0; i < numHoldingRegisters; i++) {
long holdingRegisterValue = ModbusRTUServer.holdingRegisterRead(i);
ModbusRTUServer.inputRegisterWrite(i, holdingRegisterValue);
I didn't like ATMEGA4809. (Better to use STM32F103 instead = better, faster, cheaper.)
USART - Universal Synchronous and Asynchrono ...
I would use a converter to I2C or SPI. The converters can be assembled on ATMega8.
Then each ATMega8 on the slow 9600 interface will exchange and put (take) information from the device.
And a separate controller, for example ATMega328, will collect instantly (as received or exchanged)
the necessary information with ATMega8 and do what is required.
This will give us an analogue of DMA. Otherwise, while you are working with the UART, nothing else is available.
