MODBUS RTU RS-232 Communication
I am working on a project to communicate to use an arduino to act as a MODBUS master and connect to a RTU slave device utilizing RS-232. I am currently struggling to establish communication.
Hardware
Arduino MEGA
MAX3232 RS-232 to TTL Converter (purchased off Amazon)
Converter
The converter TX is connected to the Serial1 TX and and the converter RX Serial 1 RX. This looks correct to me based on checking the pin-out of the MAX3232 chip on the converter I got.
Software:
I have tried several different libraries but am currently trying to work with this one:
Modbus-Master-Slave-for-Arduino
I am slightly modified the example code as follows:
#include <ModbusRtu.h>
// data array for modbus network sharing
uint16_t au16data[16];
uint8_t u8state;
 *  Modbus object declaration
 *  u8id : node id = 0 for master, = 1..247 for slave
 *  port : serial port
 *  u8txenpin : 0 for RS-232 and USB-FTDI
 *               or any pin number > 1 for RS-485
Modbus master(0,Serial1,0); // this is master and RS-232 or USB-FTDI
 * This is an structe which contains a query to an slave device
modbus_t telegram;
unsigned long u32wait;
  Serial.begin( 9600 ); // baud-rate at 19200
  Serial1.begin( 9600);
  master.start();
  master.setTimeOut( 2000 ); // if there is no answer in 2000 ms, roll over
  u32wait = millis() + 1000;
  u8state = 0;
  switch( u8state ) {
  case 0:
    if (millis() > u32wait) u8state++; // wait state
  case 1:
    telegram.u8id = 1; // slave address
    telegram.u8fct = 3; // function code (this one is registers read)
    telegram.u16RegAdd = 0; // start address in slave
    telegram.u16CoilsNo = 10; // number of elements (coils or registers) to read
    telegram.au16reg = au16data; // pointer to a memory array in the Arduino
    master.query( telegram ); // send query (only once)
    u8state++;
  case 2:
    master.poll(); // check incoming messages
    if (master.getState() == COM_IDLE) {
      Serial.println("idle");
      u8state = 0;
      u32wait = millis() + 100;
Serial.println(au16data[9]);
Right now I am just trying to get the Arduino to print holding register 9. I am just getting Zero out right now.
I am going to hook up an oscilloscope next and try to check the signals coming out of the arduino and out of the converter.
If anyone has a suggestion of a better library for a MODBUS Master RTU over RS-232, please let me know.
Well I moved onto a different library. I realized that library would not support the format of MODBUS RTU that I wanted to use. I am trying the library that I found in this thread:
https://forum.arduino.cc/index.php?topic=176142.0
So far I have been able to scope and decode RS232 messages. Next I will hook the system back up to the controller I am working with an see if I get any messages back from the slave.
Another update. The amazon RS-232 to TTL converter is garbage. The TX function works fine but the RX function does not at all.
Don't buy one of these:
I have a requirement as yours... I want to use a Mega2560 as master and connected to a TTL<-> RS485 converter ( data sheet attached ) which in turn is connected to a Schneider power meter EM6400.
Want to read the AC Volt / Amp / kWh etc.
I was searching for Libraries and there are many. Not sure which exactly will help me ? Can someone help on this ?
Thanks
RS485 to TTL Converter datasheet.pdf (791 KB)
