I have built a board with E01-ML01DP5 module of Ebyte and another board with module E28-2G4M27SX
E01-ML01DP5 (20dBm) works with GFSK modulation; E28-2G4M27SX (27dBm) has LORA, FLRC and GFSK modulation
With same directive antenna, module E01-ML01DP5 at baud rate=250K, is better than module E28-2G4M27SX LORA (SF=8, BW1625) and better even when FLRC is used, with baud rate 0.5Mb. Now i will try with GFSK modulation.
I have tested in continuous rx tx loop at many distances.
So far E28-2G4M27SX has been a great delusion. Any comment?
I have moved your topic to the appropriate English language category of the forum @enzo1949.
In the future, please use the forum category appropriate to the language you are posting in. The International categories should be used if you are posting in the language to which they are dedicated, while the non-"international" categories should be used if you are posting in English. This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
You might get a better response if you explain all the acronyms and provide links to their datasheets.
But first read the pinned post re 'How to get the most from the forum'. That will among other things tell you how to post all the code and any needed Serial output as well as taking a photo of your hand drawn wiring diagram.
This usually happens when you are viewing the forum with the browser configured to automatically translate the page content to your preferred language.
This is the forum category you selected when you created the topic:
The International > Deutsch category you selected should only be used when you wish to communicate in the German language. It is not appropriate to select when you are instead writing in the English language. In that case, you must use one of the English language forum categories.
In the future, please be more careful when you are selecting the category for forum topics you create. Keep in mind the possible confusion that might occur through browsing the forum with an automated translation feature enabled in your browser.
