Monitoring solar PV.
Hi everyone.
I am new here so i have some question for a new project that i am going to start.
I have this project to do. Its about solar photovoltaic modules where I have to monitoring:
Their Temperature
Their Voltage
Their current
solar irradiance
ambient temperature
I need to show these variables plotted on the internet. So my question is. As a new user in this. what Arduino and components do you recommend me to buy ( I have not bought the Arduino ).
I have knowledge in programming microcontrollers
thank you so much for yout attention and I am sorry for my english
Jose Rivas
for the temperatures i suggest a pair of ds18b20 (one under a panel and that touches it)
for the current monitor i suggest a DC-capable isolated module
for solar irradiance i suggest a photodiode like the bpw34 (you need an application circuit(browse the internet))
for their voltage it may be a bit complex...
you can try a voltage divider calculated for applying less than 5V on an analog pin, assuming you can connect the arduino gnd to the panel's gnd
you can buy an arduino UNO with an ethernet shield and a transformer type power supply, this way you are 100% sure the system is isolated from mains both on the power transformer and on the ethernet transformer and you may join the two GNDs
Thank you for your reply screwpilot.
I'm going to work con it.
