more than one Motor Driver on Arduino Uno?
Hi, I am starting a new project and got a small problem. I need to power/Control 4 Different Geared DC Motors.
As you can use two motors a Driver (H-Bridge Motor Driver 1A - COM-00315 - SparkFun Electronics) I was thinking about the problem it might give if you connect two of them on one Arduino Uno. Can it handle it? Or should i get a different Arduino, and if i need a different one, How can I get a shield that fits on the Uno to fit on it?
Yes no problem. Where are you getting your motor supply from? That might limit you but there is no problem with a separate supply.
Make it on a prototyping shield.
I'm no expert in this but as I understand one should have a fly-back diode when driving inductive loads. Reading the comments to that IC on sparkfun I saw someone mentioning that it, in contrast with the L293D, lacks internal fly-back diodes.
If you're not too interesting in doing it from the ground up I would recommend looking for a shield that manages it all for you. E.g. Overview | Adafruit Motor Shield | Adafruit Learning System
(I have a copy of that, but haven't gotten around to use it). You can also go with breakout boards and connect them to different pins on the arduino. There are many such with the L298N chip that can drive bigger loads. I haven't seen a shield with two L298N though.
