Motor position control with PID
I've made a motor position controller with Arduino. Motor is driven by L289N driver and a potentiometer is connected to its shaft. Another potentiometer is used to control the setpoint. I'm using the PID library to make the controller.
The system sort of works. Positioning works but there is lots of oscillation.
I tried Ziegler-Nichols method to tune the PID as well as trial and error but could not get any acceptable results. I can get rid of oscillations only if I put both Ki and Kd to zero. But oscillation appears as soon as I increase Ki. I tried Ki = 0.001 and there still was oscillation.
I don't know if the problem is in my code, hardware or even a bug in the PID library.
Here's my code:
#include <PID_v1.h>
const int feedbackPin = A0;  //Pin of feedback potentiometer
const int torquePin = 9; //PWM pin to motor driver
const int forwardsPin = 8; //Forwards enable pin to motor driver
const int backwardsPin = 7; //Backwards enable pin to motor driver
//PID tunings
const double Kp = 2;
const double Ki = 0.0001;
const double Kd = 0;
double setPoint;
double input;
double error;
double output;
double torque;
//Input
int i1, i2, i3, i4, i5;
PID myPID(&error, &torque, 0, Kp, Ki, Kd, REVERSE);
  input = analogRead(feedbackPin);
  setPoint = analogRead(A1);
  error = abs(setPoint - input);
  pinMode(forwardsPin, OUTPUT);
  pinMode(backwardsPin, OUTPUT);
  pinMode(3, OUTPUT);
  myPID.SetSampleTime(10);
  myPID.SetMode(AUTOMATIC);
  //Read setpoint
  if (setPoint < 25){
    setPoint = 25;
  else if (setPoint > 1000){
    setPoint = 1000;
  //Read input
  //Calculate error
  //Compute PID
  if(myPID.Compute()){
  //Write enable pins
  if (setPoint - input > 0){
    digitalWrite(forwardsPin, HIGH);
    digitalWrite(backwardsPin, LOW);
  else if (setPoint - input < 0){
    digitalWrite(forwardsPin, LOW);
    digitalWrite(backwardsPin, HIGH);
  analogWrite(torquePin, torque);
Do you think it is reasonable to attempt to run a motor intended to run thousands of rpm at such a low speed as to accurately position to a range of less than 360 degrees?
Do a little back of the napkin engineering and calculate what the motor voltage versus time profile looks like for a move from setpoint min to setpoint max. Hopefully you will be able to answer your own questions once you see what you’re asking the motor and system to do.
Gear down the motor-potentiometer connection by 100:1 and you should have no problem. This is similar to how hobby servos work.
The motor itself probably runs very fast but it has a gearbox and the output shaft is running quite slow.
I'm sure this can be done. The positioning almost works if I put Ki and Kd to zero. Then there is some overshoot which causes a little bit of oscillation but the motor settles to the right position quite quickly.
Right now the positioning looks quite the same as in this video.
My ruminations in this link about a simpler version of PID (which does the same calculations as the regular PID library) may be of interest.
As you can see I had a DIY servo working but I don't seem to have kept a copy of the specific example code for that.
...R
It seems that this was just a tuning issue. I looked for different methods of tuning PID controllers and could find Kp, Ki and Kd that work. They are much smaller than those which I got with Ziegler-Nichols method.
