PID speed controller
void encoderISR();
int pidControl(int setPoint, float actual);
// Pin definitions
const int motorPin1 = 7;
const int motorPin2 = 8;
const int enablePin = 9;
const int encoderPinA = 2;
const int encoderPinB = 3;
int output = 0;
int min = 0;
int max = 1500;
volatile unsigned long lastTime = 0;
volatile unsigned long pulseDuration = 0;
const int PPR = 240; // Pulses Per Revolution (Adjust based on your encoder)
volatile bool newPulse = false;
float speed1Prev = 0;
float speed1 = 0;
// PID constants
int antiWind = 1;
int kwd = 1;
float Kp = 0.85;
float Ki = 0.5;
float Kd = 0.5;
float integral = 0;
float previousError = 0;
long prevT = 0;
//const long interval = 100; // Interval in milliseconds for PID calculations
float integralMin = -1000;
float integralMax = 1000;
// Desired and current speed
int desiredSpeed = 120; // Desired speed in RPM
float currentSpeed = 0;
  // Set motor pins as outputs
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  pinMode(enablePin, OUTPUT);
  // Set encoder pins as inputs
  pinMode(encoderPinA, INPUT);
  pinMode(encoderPinB, INPUT);
  // Attach interrupt to encoder pin A
  attachInterrupt(digitalPinToInterrupt(encoderPinA), encoderISR, FALLING);
  digitalWrite(motorPin1, HIGH);
  digitalWrite(motorPin2, LOW);
  analogWrite(enablePin, 0);
  // Start Serial Monitor
  noInterrupts();
  float speed = speed1;
  interrupts();
  long currT = micros();
  float delta = ((float)(currT - prevT)) / 1.0e6;
  prevT = currT;
  currentSpeed = 0.854 * currentSpeed + 0.0728 * speed + 0.0728 * speed1Prev;
  speed1Prev = speed;
  Serial.print("Currentspeed:"); // serial plotter depends on this, don't give space and extra terms, units like rpm
  Serial.print(currentSpeed);
  Serial.println("");
  Serial.print("desiredspeed:");
  Serial.print(desiredSpeed);
  Serial.println("");
  Serial.print("int:");
  Serial.print(output);
  Serial.println("");
  // PID control
  int setPoint = desiredSpeed;
  float actual = currentSpeed;
  float error = setPoint - actual;
  integral = integral + (error * delta) * kwd;
  integral = constrain(integral, integralMin, integralMax);
  float derivative = (error - previousError) / delta;
  float u = Kp * error + Ki * integral + Kd * derivative;
  previousError = error;
   output = (int)fabs(u);
  int dir = 1;
  if (u < 0) {
    dir = -1;
  int pwmValue = output;
  if (pwmValue > max && pwmValue * error > 0) {
    kwd = 0;
    kwd = 1;
  if (pwmValue > 255) {
    pwmValue = 255;
  setMotor(dir, pwmValue, enablePin, motorPin1, motorPin2);
  // Delay to match the interval
  delay(100);
void setMotor(int dir, int pwmValue, int enablePin, int in1, int in2) {
  analogWrite(enablePin, pwmValue);  // Motor speed
  if (dir == 1) {
    // Turn one way
    digitalWrite(in1, LOW);
    digitalWrite(in2, HIGH);
  } else if (dir == -1) {
    // Turn the other way
    digitalWrite(in1, HIGH);
    digitalWrite(in2, LOW);
    // Or don't turn
// Encoder ISR
void encoderISR() {
  int b = digitalRead(encoderPinB);
  int increment = 0;
  if (b > 0) {
    increment = 1;
    increment = -1;
  unsigned long currentTime = micros();
  pulseDuration = currentTime - lastTime; // this can't give neg I think
  lastTime = currentTime;
  speed1 = (60.0 * 1000000.0) / (pulseDuration * (float)PPR);
will this code be able to control the speed of the motor properly?
What is the outcome running it?
currentSpeed was 280 something oscillating.
Tune your PID parameters.
There are for sure tutorials telling how to adjust the PID factors. Google is a good friend.
