Motorcycle Tachometer (rpm)
Hi everyone,
I'm actually building a dashboard for my 2 stroke 20 years old motorcycle.
The sensors on this bike for the RPM & Speed or mechanical.
What I'm trying to do is to get the signal from the primary ignition coil, exactly like in that post: https://forum.arduino.cc/index.php?topic=388852.15
Here it is my setup: https://i.imgur.com/cL7PFqv.png
Here it is the code I'm using to check what's the signal looks like:
int coilSignal = 2; // coilSignal
volatile byte counts;
unsigned int rpm; //unsigned gives only positive values
unsigned long previoustime;
void count_function()
counts++;
//Intiates Serial communications
attachInterrupt(0, count_function, FALLING); //Interrupts are called on Rise of Input
pinMode(coilSignal, INPUT); //Sets sensor as input
counts= 0;
rpm = 0;
previoustime = 0; //Initialise the values
delay(1000);//Update RPM every second
detachInterrupt(0); //Interrupts are disabled
rpm = 60*1000/(millis() - previoustime)*counts;
previoustime = millis(); //Resets the clock
counts= 0; //Resets the counter
Serial.print("RPM=");
Serial.println(rpm); //Calculated values are displayed
attachInterrupt(0, count_function, FALLING); //Counter restarted
But I finally realised that when the bike was running, even when I unplugged the wires from the bike, the serial monitor kept writing values... (up to 1 meter far away from the motorbike) :o
So I tried to find out the problem until I removed all the wires from my Arduino UNO board.
I just plugged one wire on the digital input 2, and even the wire is connected to nowhere, I have values on the monitor.
It seems like the wire plugged into that input is getting some magnetic noises which disturbed all the values I'm trying to get.
I would like to know if I'm missing something and how to solve this problem.
If anyone has a clue about that..
Thank's !
You've just discovered how much EMI an ignition system generates. You may need everything fully shielded,
arduino in metal box, shield cables, shielded box for the display, then you've got a chance of clean signals.
If you don't have suppressed leads (plug leads with a high resistance core) that's the first thing to remedy
though as copper-cored spark leads generate by far the worst interference possible.
Hi thank you very much for the answer ! I'll try to fix that problem following your advices.
I'm just wondering why with this simple code without using interrupt method, I have clear values on the serial monitor, without these kind of noises? I don't really find answers for that.
int tachSignal = 2;
int debounceSignal = 10;
unsigned long lastDebounceSignal;
int rpm;
bool readingSignal;
bool outSignal;
pinMode(tachSignal, INPUT);
void loop(){
int readingSignal = digitalRead(tachSignal);
if (readingSignal != tachSignal)
  lastDebounceSignal = millis();
if  (digitalRead(tachSignal) == LOW)
  if (millis() - lastDebounceSignal > debounceSignal)
    outSignal = LOW;
    Serial.print("LOW  ");
thank you
hi there, well. Eliminating interrupts you control the timing. isnt ? maybe is a good approach to make your own window counting pulses I mean.
there are some articles about noise in optocouplers that you might read. some use a calibration for the "integrator" at the input and others also put a fast diode to ground .
theres capacitance effect if the diode is on a higher voltage than the transistor . i couldnt find the article. ill keep searching.
