Mounting 3X4 key pad on panel
I am ready to permanently mount one of those paper-thin keypads on a plastic enclosure. Right now, my options are carpet tape or double-sided foam tape strips.
Has anyone used another method?
Thanks, Paul
Staple gun and a backer board. Ka-chunk, ka-chunk, hold that sucker in place.
Double sided tape on the back of the keypad to a none flex surface.
(deleted)
spycatcher2k:
My flex pads all come with double sided tape already fitted. Failing that, I would use any thin double sided tape, carpet tape would work.
You are so right! That wasn't mentioned by the Ebay seller, and I just presumed the paper was there for tape to adhere to. Just tried a small corner and sticky is underneath.
I am ready to go!
Thanks, Paul
