Hello Guys,
I want my arduino with MP3 shield to play a song (1 song) when a PIR sensor detects movement. I have found some projects who look a lot like my project (used that code). The difference with my project is that the other projects played a random song when movement was detected. When I ran the code below (no faults where noticed by arduino) I got no music I know it's not the hardware because my PIR sensor worked with a LED and my MP3 Shield worked with the serial monitor. Can you guys help me with this? ( I'm not an experienced programmer).
#include <SFEMP3Shield.h>
#include <SFEMP3ShieldConfig.h>
#include <SFEMP3Shieldmainpage.h>
#include <ArduinoStream.h>
#include <bufstream.h>
#include <ios.h>
#include <iostream.h>
#include <istream.h>
#include <MinimumSerial.h>
#include <ostream.h>
#include <Sd2Card.h>
#include <SdBaseFile.h>
#include <SdFat.h>
#include <SdFatConfig.h>
#include <SdFatmainpage.h>
#include <SdFatStructs.h>
#include <SdFatUtil.h>
#include <SdFile.h>
#include <SdInfo.h>
#include <SdSpi.h>
#include <SdStream.h>
#include <SdVolume.h>
#include <SPI.h>
SFEMP3Shield MP3player;
SdFat sd;
// constant variables
int pirPin = 5; // PIR sensor input pin
int calibrationTime = 10;
unsigned long playTime = 150000; // how long a file will play in milliseconds (15000=15 seconds)
unsigned long pauseTime = 10000; // how long the pause will be after the sound ends (10000=10 seconds)
int readingInterval = 20; // how often to read the sensor
// changing variables
int rantrack = 0; // track number for randomizing
unsigned long currentMillis = 0; // time variable to track running time: current time
unsigned long startingMillis = 0; // time variable to track running time: starting time
byte result; // variable for mp3 player shield, can be used to debug
// setup
pinMode(pirPin, INPUT);
digitalWrite(pirPin, LOW);
//give the sensor some time to calibrate
for(int i = 0; i < calibrationTime; i++){
delay(50);
pinMode(pirPin, INPUT); // make PIR sensor an input
digitalWrite(pirPin, LOW); // activate internal pull-up resistor
result = MP3player.begin(); // start mp3 player shield
MP3player.setVolume(10, 10); // set volume of the mp3 player ( 0 = loudest )
// loop
void loop(){
if (digitalRead(pirPin)== HIGH) { // if movement sensed
randomSeed(millis()); // set a more random seed for the random function
// find random number
result = MP3player.playTrack(1); // play track
playtime(); // call function for play time
MP3player.stopTrack(); // stop track
delay(pauseTime); // wait...
delay(readingInterval); // wait with reading
// function to determine playtime
void playtime() {
startingMillis = millis(); // set both time counter
currentMillis = millis();
while ( currentMillis - startingMillis < playTime ) { // while track plays, runs until playTime is reached
currentMillis = millis(); // set to actual time
delay(40); // debounce
