MP3 Shield + PIR sensor not working
Hi guys, I want my arduino with MP3 shield to play a song (one song, track001.mp3) when movement is noticed by the PIR sensor I'm using. This seemed to work fine (song played when movement was noticed), but after a couple of times the song started to play by itself (without detecting movement by the PIR sensor) after 20-30 sec. Do you guys know what the problem could be?
Please help me!
Thanks in advance
The sketch:
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <SFEMP3Shield.h>
SdFat sd;
SFEMP3Shield MP3player;
int pirPin = 5;    //the digital pin connected to the PIR sensor's output
  pinMode(pirPin, INPUT);
    digitalWrite(pirPin, LOW);
  //start the shield
  sd.begin(SD_SEL, SPI_HALF_SPEED);
  MP3player.begin();
  MP3player.setVolume(10, 10);
//do something else now
  if (digitalRead(pirPin) == HIGH){
      MP3player.playTrack(1);
  Serial.println("I'm bored!");
  delay(2000);
Why are you f**king with an input pin? You can't make the PIR sensor NOT report a value!
Oke, that make sense :roll_eyes: I'm kind of a noob in programming and got most of this sketch from other projects/examples. So concider
deleted. What should I do next to make this sketch work?
Okay removing the digital write...
#include <SPI.h>
#include <SdFat.h>
SdFat sd;
  //start the shield
  MP3player.begin();
      // Add the following line to test if the Pir is detecting motion
      Serial.println("Motion detected!"
  delay(2000);
Have you connected a volt meter to the pir pin and confirmed that the signal is about 5V/3.3V when the pir sensor detects motion? Also the delay(2000) means that even if the PIR is detecting motion and generating a logic HIGH, but it occurs and goes away while the 2 second delay is happening, your code will never detect it.
If you only want something to occur after a period of time has elapsed, but still want the rest of the program working, like checking if a sensor is tripped, you can't use delay you have to use something like this.
long lastBored=0;
loop()
   if ((millis() - lastBored) > 2000L)
      lastBored = millis();
      Serial.println("I'm bored");
