MPU-6050 Freezes after a little
Im using these MPU-6050 modules from Amazon, and have soldered and wired one to an Arduino R4 Minima as this Instructable shows. And have uploaded the code below. It runs well for a couple of seconds, until it suddenly freezes at one value despite my continued rotation. What should I do? Thank you.
#include <Wire.h>
#include <MPU6050.h>
MPU6050 mpu;
int16_t ax, ay, az;
  while (!Serial);
  Wire.begin();
  Wire.setClock(400000);
  mpu.initialize();
  mpu.setSleepEnabled(false);
  Serial.println("MPU Ready");
  mpu.getAcceleration(&ax, &ay, &az);
  float angleY = atan2(ay, az) * 180.0 / PI;
  Serial.println(angleY);
  if(angleY<40)
      Serial.println("!!!!");
You might want to look at the schematic that's included on that Amazon page and see what Vcc is hooked up to on that module. And then take a very critical look at that Instructables page and see what it has it has Vcc hooked up to.
Try the sample code included with the library. If it fails then most likely the MPU6050 is toast. This is why we don't solder directly to an MCU. It may even have been over heating that caused it.
The wording in my first post may have been misleading, but I meant to say I soldered the header pins on and then connected them with the wires. And I tried powering it with both 3.3v and 5v, but they both have the issue of working well for a little while before freezing.
Edit: I used the Adafruit basic readings code, and it still froze.
// Basic demo for accelerometer readings from Adafruit MPU6050
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
Adafruit_MPU6050 mpu;
void setup(void) {
  while (!Serial)
    delay(10); // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("Adafruit MPU6050 test!");
  // Try to initialize!
  if (!mpu.begin()) {
    Serial.println("Failed to find MPU6050 chip");
    while (1) {
      delay(10);
  Serial.println("MPU6050 Found!");
  mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
  Serial.print("Accelerometer range set to: ");
  switch (mpu.getAccelerometerRange()) {
  case MPU6050_RANGE_2_G:
    Serial.println("+-2G");
  case MPU6050_RANGE_4_G:
    Serial.println("+-4G");
  case MPU6050_RANGE_8_G:
    Serial.println("+-8G");
  case MPU6050_RANGE_16_G:
    Serial.println("+-16G");
  mpu.setGyroRange(MPU6050_RANGE_500_DEG);
  Serial.print("Gyro range set to: ");
  switch (mpu.getGyroRange()) {
  case MPU6050_RANGE_250_DEG:
    Serial.println("+- 250 deg/s");
  case MPU6050_RANGE_500_DEG:
    Serial.println("+- 500 deg/s");
  case MPU6050_RANGE_1000_DEG:
    Serial.println("+- 1000 deg/s");
  case MPU6050_RANGE_2000_DEG:
    Serial.println("+- 2000 deg/s");
  mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
  Serial.print("Filter bandwidth set to: ");
  switch (mpu.getFilterBandwidth()) {
  case MPU6050_BAND_260_HZ:
    Serial.println("260 Hz");
  case MPU6050_BAND_184_HZ:
    Serial.println("184 Hz");
  case MPU6050_BAND_94_HZ:
    Serial.println("94 Hz");
  case MPU6050_BAND_44_HZ:
    Serial.println("44 Hz");
  case MPU6050_BAND_21_HZ:
    Serial.println("21 Hz");
  case MPU6050_BAND_10_HZ:
    Serial.println("10 Hz");
  case MPU6050_BAND_5_HZ:
    Serial.println("5 Hz");
  Serial.println("");
  delay(100);
  /* Get new sensor events with the readings */
  sensors_event_t a, g, temp;
  mpu.getEvent(&a, &g, &temp);
  /* Print out the values */
  Serial.print("Acceleration X: ");
  Serial.print(a.acceleration.x);
  Serial.print(", Y: ");
  Serial.print(a.acceleration.y);
  Serial.print(", Z: ");
  Serial.print(a.acceleration.z);
  Serial.println(" m/s^2");
  Serial.print("Rotation X: ");
  Serial.print(g.gyro.x);
  Serial.print(g.gyro.y);
  Serial.print(g.gyro.z);
  Serial.println(" rad/s");
  Serial.print("Temperature: ");
  Serial.print(temp.temperature);
  Serial.println(" degC");
  Serial.println("");
Data point.
After disabling the internal pullups in the R4's Wire library, I hooked a handy MPU6050 up to a Minima and loaded the sketch in post #4.
It's still running just fine 30 minutes later.
How would I disable the internal pullups?
Hi, @ace595
Can you post some images of your project?
So we can see your component layout.
Thanks.. Tom.... :smiley: :+1: :coffee: :australia:
In Wire.cpp, look for lines containing R_IOPORT_PinCfg and comment out the reference to IOPORT_CFG_PULLUP_ENABLE, e.g.
    R_IOPORT_PinCfg(&g_ioport_ctrl, g_pin_cfg[sda_pin].pin, (uint32_t) (IOPORT_CFG_PULLUP_ENABLE | IOPORT_CFG_PERIPHERAL_PIN | ioport_sda));
    R_IOPORT_PinCfg(&g_ioport_ctrl, g_pin_cfg[scl_pin].pin, (uint32_t) (IOPORT_CFG_PULLUP_ENABLE | IOPORT_CFG_PERIPHERAL_PIN | ioport_scl));
to
    R_IOPORT_PinCfg(&g_ioport_ctrl, g_pin_cfg[sda_pin].pin, (uint32_t) (/*IOPORT_CFG_PULLUP_ENABLE |*/ IOPORT_CFG_PERIPHERAL_PIN | ioport_sda));
    R_IOPORT_PinCfg(&g_ioport_ctrl, g_pin_cfg[scl_pin].pin, (uint32_t) (/*IOPORT_CFG_PULLUP_ENABLE |*/ IOPORT_CFG_PERIPHERAL_PIN | ioport_scl));
If you know where to find Wire.cpp, you're likely at the level where doing this is a manageable risk. If you don't, you probably shouldn't be doing it.
This means, exactly, two.
What singular value is that?
Show your soldering of the MPU6050 pins.
Okay, so I just had to re-solder the connections. The originals were sloppy, and that must have cause it to stop after a little. Thank you everyone.
