MPU6050 and Arduino Nano - still rotating and other problems
Hello, I have an problem with my MPU6050. Everything is fine, but when I dont move with sensor, I see that there is still some motion. Can someone help me how to reduce it? I tried some "clever" ideas like if is diference smaller than .... set values to zero but it was useless. Here is the code i found on the internet and I made some small changes. Also there is a problem that the diference between position of the sensor and 3D model rise in time. After few seconds are totaly in diferent positions. How to solve this? Thanks a lot.
   Arduino and MPU6050 Accelerometer and Gyroscope Sensor Tutorial
   by Dejan, https://howtomechatronics.com
#include <Wire.h>
const int MPU = 0x68; // MPU6050 I2C address
float qw,qx,qy,qz;
float AccX, AccY, AccZ;
float GyroX, GyroY, GyroZ;
float accAngleX, accAngleY, gyroAngleX, gyroAngleY, gyroAngleZ;
float roll, pitch, yaw;
float rollOld, pitchOld, yawOld;
float AccErrorX, AccErrorY, GyroErrorX, GyroErrorY, GyroErrorZ;
float elapsedTime, currentTime, previousTime;
int c = 0;
int digitalPin = 3; // linear Hall magnetic sensor digital interface
int hallSensor ; // digital readings
// Define a maximum and minimum value for the output
float maxOutput = 1.0; // Adjust as needed
float minOutput = -1.0; // Adjust as needed
  Serial.begin(19200);
  Wire.begin();                      // Initialize comunication
  Wire.beginTransmission(MPU);       // Start communication with MPU6050 // MPU=0x68
  Wire.write(0x6B);                  // Talk to the register 6B
  Wire.write(0x00);                  // Make reset - place a 0 into the 6B register
  Wire.endTransmission(true);        //end the transmission
  // Configure Accelerometer Sensitivity - Full Scale Range (default +/- 2g)
  Wire.write(0x1C);                  //Talk to the ACCEL_CONFIG register (1C hex)
  Wire.write(0x10);                  //Set the register bits as 00010000 (+/- 8g full scale range)
  // Configure Gyro Sensitivity - Full Scale Range (default +/- 250deg/s)
  Wire.write(0x1B);                   // Talk to the GYRO_CONFIG register (1B hex)
  Wire.write(0x10);                   // Set the register bits as 00010000 (1000deg/s full scale)
  delay(20);
  // Call this function if you need to get the IMU error values for your module
  calculate_IMU_error();
  delay(20);
  hallSensor = digitalRead(digitalPin);
  //calculate_IMU_error();
  // === Read acceleromter data === //
  Wire.write(0x3B); // Start with register 0x3B (ACCEL_XOUT_H)
  Wire.endTransmission(false);
  Wire.requestFrom(MPU, 6, true); // Read 6 registers total, each axis value is stored in 2 registers
  //For a range of +-2g, we need to divide the raw values by 16384, according to the datasheet
  AccX = (Wire.read() << 8 | Wire.read()) / 16384.0; // X-axis value
  AccY = (Wire.read() << 8 | Wire.read()) / 16384.0; // Y-axis value
  AccZ = (Wire.read() << 8 | Wire.read()) / 16384.0; // Z-axis value
  // Calculating Roll and Pitch from the accelerometer data
  accAngleX = (atan(AccY / sqrt(pow(AccX, 2) + pow(AccZ, 2))) * 180 / PI) - AccErrorX; // AccErrorX ~(0.58) See the calculate_IMU_error()custom function for more details
  accAngleY = (atan(-1 * AccX / sqrt(pow(AccY, 2) + pow(AccZ, 2))) * 180 / PI) + AccErrorY; // AccErrorY ~(-1.58)
  // === Read gyroscope data === //
  previousTime = currentTime;        // Previous time is stored before the actual time read
  currentTime = millis();            // Current time actual time read
  elapsedTime = (currentTime - previousTime) / 1000; // Divide by 1000 to get seconds
  Wire.write(0x43); // Gyro data first register address 0x43
  Wire.requestFrom(MPU, 6, true); // Read 4 registers total, each axis value is stored in 2 registers
  GyroX = (Wire.read() << 8 | Wire.read()) / 131.0; // For a 250deg/s range we have to divide first the raw value by 131.0, according to the datasheet
  GyroY = (Wire.read() << 8 | Wire.read()) / 131.0;
  GyroZ = (Wire.read() << 8 | Wire.read()) / 131.0;
  // Correct the outputs with the calculated error values
  GyroX = GyroX + (-1.4); // GyroErrorX ~(-0.56)
  GyroY = GyroY - (-0.3); // GyroErrorY ~(2)
  GyroZ = GyroZ + GyroErrorZ; // GyroErrorZ ~ (-0.8)
  // Currently the raw values are in degrees per seconds, deg/s, so we need to multiply by sendonds (s) to get the angle in degrees
  gyroAngleX = gyroAngleX + GyroX * elapsedTime; // deg/s * s = deg
  gyroAngleY = gyroAngleY + GyroY * elapsedTime;
  yaw =  yaw + GyroZ * elapsedTime;
  // Complementary filter - combine acceleromter and gyro angle values
  roll = 0.96 * gyroAngleX + 0.04 * accAngleX;
  pitch = 0.96 * gyroAngleY + 0.04 * accAngleY;
  // vypocet kvaternionov
  qw = cos(roll / 2.0) * cos(pitch / 2.0) * cos(yaw / 2.0) + sin(roll / 2.0) * sin(pitch / 2.0) * sin(yaw / 2.0);
  qx = sin(roll / 2.0) * cos(pitch / 2.0) * cos(yaw / 2.0) - cos(roll / 2.0) * sin(pitch / 2.0) * sin(yaw / 2.0);
  qy = cos(roll / 2.0) * sin(pitch / 2.0) * cos(yaw / 2.0) + sin(roll / 2.0) * cos(pitch / 2.0) * sin(yaw / 2.0);
  qz = cos(roll / 2.0) * cos(pitch / 2.0) * sin(yaw / 2.0) - sin(roll / 2.0) * sin(pitch / 2.0) * cos(yaw / 2.0);
  // Print the values on the serial monitor
  Serial.print(roll);
  Serial.print("/");
  Serial.print(pitch);
  Serial.print("/");
  Serial.println(yaw);
void calculate_IMU_error() {
  // We can call this funtion in the setup section to calculate the accelerometer and gyro data error. From here we will get the error values used in the above equations printed on the Serial Monitor.
  // Note that we should place the IMU flat in order to get the proper values, so that we then can the correct values
  // Read accelerometer values 200 times
  while (c < 200) {
    Wire.write(0x3B);
    AccX = (Wire.read() << 8 | Wire.read()) / 16384.0 ;
    AccY = (Wire.read() << 8 | Wire.read()) / 16384.0 ;
    AccZ = (Wire.read() << 8 | Wire.read()) / 16384.0 ;
    // Sum all readings
    AccErrorX = AccErrorX + ((atan((AccY) / sqrt(pow((AccX), 2) + pow((AccZ), 2))) * 180 / PI));
    AccErrorY = AccErrorY + ((atan(-1 * (AccX) / sqrt(pow((AccY), 2) + pow((AccZ), 2))) * 180 / PI));
    c++;
  //Divide the sum by 200 to get the error value
  AccErrorX = AccErrorX / 200;
  AccErrorY = AccErrorY / 200;
  c = 0;
  // Read gyro values 200 times
  while (c < 200) {
    Wire.write(0x43);
    GyroX = Wire.read() << 8 | Wire.read();
    GyroY = Wire.read() << 8 | Wire.read();
    GyroZ = Wire.read() << 8 | Wire.read();
    // Sum all readings
    GyroErrorX = GyroErrorX + (GyroX / 131.0);
    GyroErrorY = GyroErrorY + (GyroY / 131.0);
    GyroErrorZ = GyroErrorZ + (GyroZ / 131.0);
    c++;
  GyroErrorX = GyroErrorX / 200;
  GyroErrorY = GyroErrorY / 200;
  GyroErrorZ = GyroErrorZ / 200;
  // Print the error values on the Serial Monitor
  Serial.print("AccErrorX: ");
  Serial.println(AccErrorX);
  Serial.print("AccErrorY: ");
  Serial.println(AccErrorY);
  Serial.print("GyroErrorX: ");
  Serial.println(GyroErrorX);
  Serial.print("GyroErrorY: ");
  Serial.println(GyroErrorY);
  Serial.print("GyroErrorZ: ");
  Serial.println(GyroErrorZ);
Most likely, these offset corrections are wrong. Where did they come from?
well I found on the internet this code for Processing IDE and I just try to set those values the best I can. When I saw it rotates in some way I changed values. But there are still motions. I think there should be some filter or idk...
    Arduino and MPU6050 IMU - 3D Visualization Example
import processing.serial.*;
import java.awt.event.KeyEvent;
import java.io.IOException;
Serial myPort;
String data="";
float roll, pitch,yaw;
  size (1000, 800, P3D);
  myPort = new Serial(this, "COM3", 19200); // starts the serial communication
  myPort.bufferUntil('\n');
void draw() {
  translate(width/2, height/2, 0);
  background(233);
  textSize(22);
  text("Roll: " + int(roll) + "     Pitch: " + int(pitch), -100, 265);
  // Rotate the object
  rotateX(radians(pitch));
  rotateZ(radians(roll));
  rotateY(radians(yaw));
  // 3D 0bject
  textSize(30);
  fill(0, 76, 153);
  box (386, 40, 200); // Draw box
  textSize(25);
  fill(255, 255, 255);
  text("www.HowToMechatronics.com", -183, 10, 101);
  //delay(10);
  //println("ypr:\t" + angleX + "\t" + angleY); // Print the values to check whether we are getting proper values
// Read data from the Serial Port
void serialEvent (Serial myPort) {
  // reads the data from the Serial Port up to the character '.' and puts it into the String variable "data".
  data = myPort.readStringUntil('\n');
  // if you got any bytes other than the linefeed:
  if (data != null) {
    data = trim(data);
    // split the string at "/"
    String items[] = split(data, '/');
    if (items.length > 1) {
      //--- Roll,Pitch in degrees
      roll = float(items[0]);
      pitch = float(items[1]);
      yaw = float(items[2]);
Hi, @tomasburancgi
Did you write this code?
Any reason you did not use a Library to read the sensor?
https://www.arduino.cc/reference/en/libraries/mpu6050/
What motion, what outputs?
Thanks... Tom... :grinning: :+1: :coffee: :australia:
The usual approach is to average a couple hundred gyro readings at startup, then subtract those from subsequent readings.
Example:
// MPU-6050 Short Example Sketch
// Public Domain
#include<Wire.h>
const int MPU_addr = 0x68; // I2C address of the MPU-6050
int16_t AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ;
float gx = 0.0;  //gyro offsets
float gy = 0.0;
float gz = 0.0;
  Wire.begin();
  Wire.beginTransmission(MPU_addr);
  Wire.write(0x6B);  // PWR_MGMT_1 register
  Wire.write(0);     // set to zero (wakes up the MPU-6050)
  Serial.println("Keep sensor still until gyro offsets printed");
  delay(2000);
  // collect gyro data for calibration
  for (int i = 0; i < 500; i++) {
    Wire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
    Wire.requestFrom(MPU_addr, 14); // request a total of 14 registers
    AcX = Wire.read() << 8 | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
    AcY = Wire.read() << 8 | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
    AcZ = Wire.read() << 8 | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
    Tmp = Wire.read() << 8 | Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
    GyX = Wire.read() << 8 | Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
    GyY = Wire.read() << 8 | Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
    GyZ = Wire.read() << 8 | Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
    gx += GyX; gy += GyY; gz += GyZ;
  gx = gx / 500.0;
  gy = gy / 500.0;
  gz = gz / 500.0;
  Serial.print("Gyro offsets ");
  Serial.print(gx);
  Serial.print(", ");
  Serial.print(gy);
  Serial.print(", ");
  Serial.println(gz);
    Serial.println("corrected gyro values follow");
  Wire.requestFrom(MPU_addr, 14, true); // request a total of 14 registers
  Serial.print(GyX-gx);
  Serial.print(", ");
  Serial.print(GyY-gy);
  Serial.print(", ");
  Serial.println(GyZ-gz);
  delay(200);
No that code is not mine. I just made some changes. Well that library is great and Sketch example MPU6050_raw works for me. I see there is part in the code:
    // use the code below to change accel/gyro offset values
    Serial.println("Updating internal sensor offsets...");
    // -76	-2359	1688	0	0	0
    Serial.print(accelgyro.getXAccelOffset()); Serial.print("\t"); // -76
    Serial.print(accelgyro.getYAccelOffset()); Serial.print("\t"); // -2359
    Serial.print(accelgyro.getZAccelOffset()); Serial.print("\t"); // 1688
    Serial.print(accelgyro.getXGyroOffset()); Serial.print("\t"); // 0
    Serial.print(accelgyro.getYGyroOffset()); Serial.print("\t"); // 0
    Serial.print(accelgyro.getZGyroOffset()); Serial.print("\t"); // 0
    Serial.print("\n");
    accelgyro.setXGyroOffset(220);
    accelgyro.setYGyroOffset(76);
    accelgyro.setZGyroOffset(-85);
    Serial.print("\n");
Here I should add my data from IMU_Zero, right? I would like to ask you some things. I get this data:
16:42:40.301 -> .................... XAccel YAccel ZAccel XGyro YGyro ZGyro
16:43:27.655 -> [2109,2110] --> [0,20] [-2171,-2170] --> [-9,10] [1167,1168] --> [16381,16393] [-44,-43] --> [0,4] [13,14] --> [0,5] [-12,-11] --> [-2,1]
16:43:30.248 -> .................... [2109,2109] --> [0,1] [-2171,-2170] --> [-10,10] [1167,1168] --> [16375,16393] [-44,-43] --> [0,4] [13,14] --> [0,5] [-12,-11] --> [-2,1]
16:44:17.706 -> -------------- done --------------
Which values should I set? Its mess for me to be honest.
See post #5.
