MPU6050 raw values check
Hi
I've been trying to read raw values from MPU6050 and my problem is, instead of getting negative values when i go the opposite direction (accelerometer) or rotate the opposite direction (gyroscope), i get the end scale reading.
My gyro FS is set to 1 i.e. +/- 500 deg/s and accelerometer AFS is set to 1 i.e. +/- 8g.
When I try to read Z axis gyro readings, instead of getting negative values, i get something in the range of 65500. And in the case of the accerometer z-axis, when i hold the MPU6050 upside down, I exected to get a raw value in the ballpark of -4096 but again, it reads something in the range of 65500.
Can someone help me with this? What am I missing?
Code.
Fair enough. Here you go
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
long gyro_x, gyro_y, gyro_z;
long acc_x, acc_y, acc_z, acc_total_vector;
int temperature;
long gyro_x_cal, gyro_y_cal, gyro_z_cal;
  if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
    //Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  display.display();
  delay(100);
  display.clearDisplay();
  display.setTextSize(2);
  display.setTextColor(SSD1306_WHITE);
  display.setCursor(0,1);
  display.println("Gyro setup...");
  display.display();
  //Activate the MPU-6050
  Wire.beginTransmission(0x68);                                        //Start communicating with the MPU-6050
  Wire.write(0x6B);                                                    //Send turn-on command
  Wire.write(0x00);                                                    //Send reset command
  Wire.endTransmission();                                              //End the transmission
  delay(200);
  //Configure the accelerometer (+/-8g)
  Wire.write(0x1C);                                                    //Send accelerometer self-test command
  Wire.write(0x10);
  //Configure the gyroscope (+/-500 deg/s)
  Wire.write(0x1B);
  Wire.write(0x10);
  display.println("Setup done");
  display.display();//End the transmission
  delay(200);
  readmpu();
  display.setCursor(25,10);
  display.print(acc_z);
  display.display();
  delay(50);
void readmpu()
  Wire.write(0x3B);                                                    //Send the requested starting register
  Wire.requestFrom(0x68,14);                                           //Request 14 bytes from the MPU-6050
  while(Wire.available() < 14);                                        //Wait until all the bytes are received
  acc_x = Wire.read()<<8|Wire.read();                                  //Add the low and high byte to the acc_x variable
  acc_y = Wire.read()<<8|Wire.read();                                  //Add the low and high byte to the acc_y variable
  acc_z = Wire.read()<<8|Wire.read();                                  //Add the low and high byte to the acc_z variable
  temperature = Wire.read()<<8|Wire.read();                            //Add the low and high byte to the temperature variable
  gyro_x = Wire.read()<<8|Wire.read();                                 //Add the low and high byte to the gyro_x variable
  gyro_y = Wire.read()<<8|Wire.read();                                 //Add the low and high byte to the gyro_y variable
  gyro_z = Wire.read()<<8|Wire.read();
Shouldn't these be "int"?
it doesnt make any difference, the error still is the same
These should be 16 bit signed integers, e.g.
int16_t gyro_x, gyro_y, gyro_z;
int16_t acc_x, acc_y, acc_z, acc_total_vector;
Also, in C/C++ this is not guaranteed to work in the correct order (it does in gcc, but not with some other compilers).
Instead use something like the following:
// MPU-6050 Short Example Sketch
// By Arduino User JohnChi
// August 17, 2014
// Public Domain
#include<Wire.h>
const int MPU_addr = 0x68; // I2C address of the MPU-6050
int16_t AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ;
  Wire.begin();
  Wire.beginTransmission(MPU_addr);
  Wire.write(0x6B);  // PWR_MGMT_1 register
  Wire.write(0);     // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
  Wire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
  Wire.endTransmission(false);
  Wire.requestFrom(MPU_addr, 14); // request a total of 14 registers
  int16_t t = Wire.read();
  AcX = (t << 8) | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
  t = Wire.read();
  AcY = (t << 8) | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
  t = Wire.read();
  AcZ = (t << 8) | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
  t = Wire.read();
  Tmp = (t << 8) | Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
  t = Wire.read();
  GyX = (t << 8) | Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
  t = Wire.read();
  GyY = (t << 8) | Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
  t = Wire.read();
  GyZ = (t << 8) | Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
  t = Wire.read();
  Serial.print("AcX = "); Serial.print(AcX);
  Serial.print(" | AcY = "); Serial.print(AcY);
  Serial.print(" | AcZ = "); Serial.print(AcZ);
  Serial.print(" | Tmp = "); Serial.print(Tmp / 340.00 + 36.53); //equation for temperature in degrees C from datasheet
  Serial.print(" | GyX = "); Serial.print(GyX);
  Serial.print(" | GyY = "); Serial.print(GyY);
  Serial.print(" | GyZ = "); Serial.println(GyZ);
  delay(333);
Hey thanks a lot for your timely response! Your first suggestion to use signed 16bit integers worked perfectly!!
Also if you dont mind, could you elaborate on the second change you suggested??
In the C/C++ language, there is no requirement for left to right ordering of the function calls above, so you may end up with the two bytes swapped. Depends on the compiler.
aka "int" (on AVRs)
