Hello!
I have an MPU 6050 gyro accelerometer. It does read correctly sometimes but every few cycles the rotation reads at around 500 degrees/second and the accelerometers read 3 Gs for no particular reason. Why is this and how do I fix it?
Here is the serial output which has the "glitchy" reads:
Gyro (deg) X=466.47 Y=250.14 Z=138.16 Accel (g) X=0.19 Y=0.09 Z=0.22
Gyro (deg) X=5.47 Y=489.23 Z=493.11 Accel (g) X=0.25 Y=0.02 Z=3.93
here are some of the incorrect values
Gyro (deg) X=112.27 Y=250.13 Z=79.59 Accel (g) X=0.22 Y=0.01 Z=0.08
Gyro (deg) X=4.21 Y=4.02 Z=497.08 Accel (g) X=0.09 Y=0.02 Z=0.19
Gyro (deg) X=9.56 Y=2.88 Z=1.30 Accel (g) X=0.09 Y=0.01 Z=0.19
Gyro (deg) X=497.73 Y=4.52 Z=3.35 Accel (g) X=0.12 Y=0.01 Z=0.17
#include <Wire.h>
long accelX, accelY, accelZ;
float gForceX, gForceY, gForceZ;
long gyroX, gyroY, gyroZ;
float rotX, rotY, rotZ;
Wire.begin();
setupMPU();
recordAccelRegisters();
recordGyroRegisters();
printData();
void setupMPU(){
Wire.beginTransmission(0b1101000); //This is the I2C address of the MPU (b1101000/b1101001 for AC0 low/high datasheet sec. 9.2)
Wire.write(0x6B); //Accessing the register 6B - Power Management (Sec. 4.28)
Wire.write(0b00000000); //Setting SLEEP register to 0. (Required; see Note on p. 9)
Wire.endTransmission();
Wire.beginTransmission(0b1101000); //I2C address of the MPU
Wire.write(0x1B); //Accessing the register 1B - Gyroscope Configuration (Sec. 4.4)
Wire.write(0x00000000); //Setting the gyro to full scale +/- 250deg./s
Wire.write(0x1C); //Accessing the register 1C - Acccelerometer Configuration (Sec. 4.5)
Wire.write(0b00010000); //Setting the accel to +/- 2g
void recordAccelRegisters() {
Wire.write(0x3B); //Starting register for Accel Readings
Wire.requestFrom(0b1101000,6); //Request Accel Registers (3B - 40)
while(Wire.available() < 6);
accelX = Wire.read()<<8|Wire.read(); //Store first two bytes into accelX
accelY = Wire.read()<<8|Wire.read(); //Store middle two bytes into accelY
accelZ = Wire.read()<<8|Wire.read(); //Store last two bytes into accelZ
processAccelData();
void processAccelData(){
gForceX = accelX / 16384.0;
gForceY = accelY / 16384.0;
gForceZ = accelZ / 16384.0;
void recordGyroRegisters() {
Wire.write(0x43); //Starting register for Gyro Readings
Wire.requestFrom(0b1101000,6); //Request Gyro Registers (43 - 48)
gyroX = Wire.read()<<8|Wire.read(); //Store first two bytes into accelX
gyroY = Wire.read()<<8|Wire.read(); //Store middle two bytes into accelY
gyroZ = Wire.read()<<8|Wire.read(); //Store last two bytes into accelZ
processGyroData();
void processGyroData() {
rotX = gyroX / 131.0;
rotY = gyroY / 131.0;
rotZ = gyroZ / 131.0;
void printData() {
Serial.print("Gyro (deg)");
Serial.print(" X=");
Serial.print(rotX);
Serial.print(" Y=");
Serial.print(rotY);
Serial.print(" Z=");
Serial.print(rotZ);
Serial.print(" Accel (g)");
Serial.print(gForceX);
Serial.print(gForceY);
Serial.println(gForceZ);
