MQ-135 range of value for NH3,NOx, alcohol, Benzene, smoke,CO2
Hello people!
I started to use Arduino for a few months in college and I like it so much I wanted to buy one for myself and after some time I discovered the MQ-135 sensor but I want to know exactly the level of PPM of NH3,NOx, alcohol, Benzene, smoke,CO2 like when is it present in the air and how much based on that PPM because I want to make a graphic evolution of NH3,NOx, alcohol, Benzene, smoke,CO2 found in the air outside my house. Can anyone help me?
I only found that it starts from 10 for every one of those but i want to know exactly for each one.
Thank you!
The MQ-135 responds to several different gases. If the MQ-135 readings change, without additional information it is impossible to say which gas might be causing the change.
jremington:
Thanks!
You will need specific sensors for each of these gases.
Expect each of those to cost 10-100 times what an MQ135 costs (though I may be underestimating the cost of those sensors).
The MQ 135 Air Quality Sensor while fine for basic hobby applications is hardly a sensor which will give you accurate numbers. Even with known gas samples, which are expensive, they do not have very good repeatability. I have to agree with wvmarie and figure even higher cost plus sample calibration gasses it's an expensive proposition.
Ron
wvmarle:
I understand, thank you very much!
