MQTT payload to INT
I am having an issue settings a variable to an int.
The goal is to change the pwm write value when I send the message over MQTT (0-1023)
When i send 0-1023 over mqtt to the board I get really long numbers IE. when i send 1023 i get: 49485051
when i send 0 i get: 48
any help is appreciated!
Problem Code
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
    String pwmValue_str = "";
    pwmValue_str = payload[i];
    analogWrite(14, pwmValue_str.toInt());
Whole Sketch
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
const char* ssid = "SSID";
const char* password = "PW";
const char* mqtt_server = "192.168.1.88";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
  pinMode(BUILTIN_LED, OUTPUT);     // Initialize the BUILTIN_LED pin as an output
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.print("] ");
  // Switch on the LED if an 1 was received as first character
  if ((char)payload[0] == '1') {
    digitalWrite(BUILTIN_LED, LOW);   // Turn the LED on (Note that LOW is the voltage level
    // but actually the LED is on; this is because
    // it is acive low on the ESP-01)
    digitalWrite(BUILTIN_LED, HIGH);  // Turn the LED off by making the voltage HIGH
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("ESP8266Client_020618-03")) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      //client.publish("outTopic", "hello world");
      // ... and resubscribe
      client.subscribe("inTopic");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
  if (!client.connected()) {
    reconnect();
  client.loop();
  /*long now = millis();
  if (now - lastMsg > 2000) {
    lastMsg = now;
    ++value;
    snprintf (msg, 75, "hello world #%ld", value);
    Serial.print("Publish message: ");
    Serial.println(msg);
    client.publish("outTopic", msg);
ELECTRONIC_VALVE_CONTROLLER_MQTT.ino (2.23 KB)
sramirez6208:
I wonder what the integer value of an ASCII zero is.
Why are you converting the payload to an int, one character at a time?
What value do you suppose b will have when the ith element of payload is 7?
   byte b = payload[i] - '0';
If you don't KNOW, try this code out, and learn.
It REALLY seems to me, though, that you want to make a string (NOT a f**king String) out of payload, and convert that string to an int.
   payload[length] = '\0'; // Make payload a string by NULL terminating it.
   int pwmVal = atoi((char *)payload);
What device are you using that takes PWM values in the range 0 to 1023?
That's it!!!!!!
Please excuse my ignorance when it comes to programming I am just getting into it.
This was a huge help, I really appreciate it.
sramirez6208:
Problem Code
  Serial.print("] ");
Whole Sketch
long lastMsg = 0;
char msg[50];
int value = 0;
  setup_wifi();
void setup_wifi() {
delay(10);
    Serial.print(".");
Serial.println("");
  Serial.print("] ");
void reconnect() {
      delay(5000);
    reconnect();
  client.loop();
    lastMsg = now;
    ++value;
