So, I have x100 NPN transitors, some of them are 2N2222A, some are 2N3094. All of them can handle atleast 500mA, which is max. safery current. Can I connect, lets say, 10, to make them transmit 5A current? And if this is somehow possible, can someone pls explain me how?
You can parallel transistors in some applications to increase their current capability but it’s a fools errand, especially when the devices are unmatched and even worse, different part numbers. Spend $2 buy the part you need rather wasting way more time and money trying to use what you have.
This one.
Simple fact is that transistors do not share current very well. It is because of their positive temperature coefficient. When a transistor passes any current it will get warm, as it gets warm it will pass more current. So any mismatch in current between transistors gets magnified until a point where one transistor is taking all the current and pops. This then puts the strain on the other transistors which go pop one after the other.
FETs in the other hand have a negitave temperature coefficient which means the hotter they get the less current will flow, this forces parallel devices to share current evenly.
The normal way to share current with transistors is to add a small value resistor on each emitter, which will
drop voltage to even-out the currents between devices. But for high current MOSFET every time, much better.
Just make sure its a logic-level MOSFET and has a low-enough on-resistance (do NOT go by the max current
handling specification of a MOSFET, that is never practical as its a power limit, ie with the device on a huge
heatsink - always calculate the dissipation with I-squared-R)
For instance the "30A" MOSFETs pointed out by ChrisTenone will handle 5A, but only just(*), as they have
50 milliohm resistance. 2 milliohm devices are available which would be able to handle a full 30A without
water-cooling!
Darlington pair devices can also handle larger currents but will need heatsinking too as they drop 1 to 2V.
(*) 1.25 watts means a small heatsink is needed though.
