Hello,
I've got two DS18B20 with "waterproof" housing and communicate using the OneWire library and an old Arduino NG. I brew beer from time to time and I'm checking if these sensors will work for monitoring the process. This means they will be in very warm water, sometimes boiling hot.
I got everything working with the code below at room temperature. I then proceeded to put one of them in some water while i heated it until it was boiling. At about 65-70C I stopped getting values from the sensor that was not in the water. Sometimes it reported back but with a weird device adress. A few more C and they both stopped working. I then disconnected the sensor that was not in the water and the other sensor started working again. When the boiled sensor cooled down they both worked again.
My theory is that when larger values are returned from the sensor it will somehow interfere with the onewire communication alltogether. Any ideas?
I got the code from a guide on the interwebs. I modified it somewhat so that it would only print device adress and temperature for my project.
#include <OneWire.h>
// DS18S20 Temperature chip i/o
OneWire ds(10); // on pin 10
void setup(void) {
// initialize inputs/outputs
// start serial port
void loop(void) {
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
byte i;
byte present = 0;
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
// Serial.print("No more addresses.\n");
ds.reset_search();
return;
Serial.print("R=");
for( i = 0; i < 8; i++) {
Serial.print(addr[i], HEX);
Serial.print(" ");
Serial.print("\n");
if ( OneWire::crc8( addr, 7) != addr[7]) {
// Serial.print("CRC is not valid!\n");
return;
if ( addr[0] == 0x10) {
Serial.print("Device is a DS18S20 family device.\n");
else if ( addr[0] == 0x28) {
// Serial.print("Device is a DS18B20 family device.\n");
else {
Serial.print("Device family is not recognized: 0x");
Serial.println(addr[0],HEX);
return;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
// Serial.print("P=");
// Serial.print(present,HEX);
// Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
// Serial.print(data[i], HEX);
// Serial.print(" CRC=");
// Serial.print( OneWire::crc8( data, 8), HEX);
// Serial.println();
LowByte = data[0];
HighByte = data[1];
TReading = (HighByte << 8) + LowByte;
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
Serial.print("D=");
if (SignBit) // If its negative
Serial.print("-");
Serial.print(Whole);
Serial.print(".");
if (Fract < 10)
Serial.print("0");
Serial.print(Fract);
Serial.print("\n");
