I use an ATMEGA328PB and 2 peripherals : MAX17841B and MCP2518FD.
So I use the SPI interface to control one or the other, but also to program the micro controller.
I connected the MISO MOSI and SCK pins directly to the ICSP connector in order to program it, and to avoid interference, I have 150 ohm resistors that go to both interfaces (MAX17841 and MCP2518FD)
The two interfaces (MAX17841 and MCP2518FD) have a resistance of 150 Ohm on their CS pin
My question is: how to properly manage the 2 interfaces? Should I add pull-up or pull-down resistors? PESD5V0U1UA, 115 connected to ground on the pins in order to protect?
it is an evaluation board of one of the modules, fear to see several protection on the lines, but on the MCP2518FD in the documentation there is nothing, no pull-up or nothing ...
Well, at the very beginning I had directly connected the connector and the chips without having any resistors and 9 times out of 10 the programming failed
I solved this by adding resistors only on the interfaces side and just leaving the lines on the icsp connector
EDIT : Now that I think about it by adding pull-up resistors on the CS pins, that would have solved the problems right?
Ok I modified everything a bit, now my SPI lines (MISO MOSI SCK) therefore have a 150 Ohm resistor, ESD protection, and the MISO line is put with a pull-up resistor
If you have a DMM you can always measure the voltage drop across all the 150 ohm
resistors , calculate the current (I=V/R) and look for anomolies or inconsistencies.
