Multiple Libraries
Hello,
I have been working with the arduino Uno for about 2 years now and have just now started to use libraries. I understand how to install a library, but I was wondering if there was a way to install several at once.
I have about 43 zip files for different projects, but going sketch>Include Library>Add .zip Library is only OK for a few libraries as you have to put them into the IDE separately. I can do that, but it is just a hassle.
So i was hoping if anyone had a way to put several libraries in without doing them separately, even if it means moving the libraries to the IDE and then walking away for 5 minutes.
I am running version 1.6.9 if it helps.
PS for the people complaining as to why i have this many libraries, they for all sorts of things, such as memory reduction, touchscreen coms, external program communications, etc.
You can simply manually unzip the zip files to c:/program files(x86)/arduino/libraries or C:\Users\windows login name\Documents\Arduino\libraries
Oh and you will have to restart the IDE after doing that othrwise it wont be able to 'see' the new libraries.
Thanks!
I have been looking for a way to do this for ages and i never thought of placing them straight into the libraries folder.
They are all in there now. Without your help, this would have taken hours.
Techmokid:
Thanks!
Be aware that, if you use the program files(x86)/arduino/libraries folder then you may run into library conflicts.
Arduino uses the users/..... folder when it updates libraries and it may install duplicates of libraries you have in the other folder.
It a frigging pain in the ar$hole I have to say.
If you modify any libraries yourself and you are using the users/.... folder then it may pay to rename them so that arduino doesn't go and overwrite your modifications when it updates again.
