I want to connect multiple piezo sensors to my Arduino Uno. 6 sensors in total.
The goal is to measure pressure from interaction with a foam ball with the piezo's.
I've done the practical part, and i need to code the piezo's, so i can monitor them (for now just in the serial monitor).
This is what i have atm.:
// these constants won't change:
const int ledPin = 13; // led connected to digital pin 13
const int knockSensor = A0; // the piezo is connected to analog pin 0
const int knockSensor2 = A1;
const int knockSensor3 = A2;
//etc. etc.
const int threshold = 100; // threshold value to decide when the detected sound is a knock or not
// these variables will change:
int sensorReading = 0; // variable to store the value read from the sensor pin
int sensorReading2 = 0;
int ledState = LOW; // variable used to store the last LED status, to toggle the light
pinMode(ledPin, OUTPUT); // declare the ledPin as as OUTPUT
Serial.begin(9600); // use the serial port
int minThres = 50;
int maxThres = 150;
//perhaps an array? sensorReadingArray[6] = {sensorReading, sensorReading2, etc.)
// read the sensor and store it in the variable sensorReading:
sensorReading = analogRead(knockSensor);
sensorReading2 = analogRead(knockSensor2);
// if the sensor reading is greater than the threshold:
if (sensorReading >= threshold) {
// toggle the status of the ledPin:
ledState = !ledState;
// update the LED pin itself:
digitalWrite(ledPin, ledState);
if (sensorReading2 >= threshold) {
Serial.println(sensorReading);
Serial.println(sensorReading2);
//Her måler vi om tingene er = 50 eller over, eller = 150 præcis.
//Ellers kan vi måle hvad sensorReading fra piezo er: Serial.println(sensorReading);
if ((sensorReading > 50) && (sensorReading < 150)) {
Serial.println("Peizo sensor 1 er mellem 50 og 150");
Serial.println("Out of range");
delay(300);
The code is clunky, and doesn't work properly.
Do you have any suggestions? Do i have to make an array of all the piezo sensorReadings?
I have found this example with MIDI's and a piano:
It now only prints when value is above threshold, the delay is removed to make it more responsive.
superfluous comments are removed too
const int knockSensor[6] = { A0, A1, A2, A3, A4, A5 };
int sensorReading[6] = {0, 0, 0, 0, 0, 0};
int ledState = LOW;
Serial.begin(115200); // use the serial port AT HIGHEST SPEED!
int minThres = 50;
int maxThres = 150;
for (int i = 0; i < 6; i++)
// read twice to minimize interference
sensorReading[i] = analogRead(knockSensor[i]);
if (sensorReading[i] >= threshold)
Serial.println(sensorReading[i]);
// do not use delay() as it is blocking...
@robtillaart Looks smooth! Had a feeling i had to make the sensors an array.
Gonna give it a go soon.
I have a few questions:
Why do you set the integer array to 0 at every placeholder? Is it because we define the values of the sensorReadings in the forloop:
This means it will use the port at highest speed. Will that work in every arduino case?
I thought the standard were 9600.
The for-loop has // read twice to minimize interference.
What does this mean basically? interference for what?
Again, thank you for helping me with this!
Edit: Oh, and please tell me to elaborate, if you're unsure of my question.
English isn't my mother tongue.
That explains it all, but i do want you to elaborate on the last part.
The Arduino has one ADC = The Arduino is meant to only have one analog reading input (in this case by a piezo)?
Im actually using the Arduino in combination with my semester final project.
If you want me to, i can upload a photo of what i have atm.?
Would love some feedback / ideas.
robtillaart:
...a measurement from another pin might affect the current reading. Two readings minimizes this effect.
A "ghost charge" of the previous read could still be present on the sample cap of the A/D converter.
A bit like eating different snacks on a party.
If you try another snack, there is still some left in your mouth from the previous one.
Untill you take a second bite byte.
Leo..
unsigned long previousMillis = 0; // will store last time LED was updated
const long interval = 1000; // interval at which to blink (milliseconds)
int ledState = LOW;
Serial.begin(38400); // use the serial port AT HIGHEST SPEED!
unsigned long currentMillis = millis(); //igangsætter sekundttæller metoden fra 0; tæller 1 sekund (se variabler)
int minThres = 50;
int maxThres = 150;
sensorReading[i] = analogRead(knockSensor[i]); //Måler 12 gange (2x6)
if (sensorReading[i] > minThres && sensorReading[i] < maxThres)
if (currentMillis - previousMillis >= 4000)
{ // save the last time you blinked the LED - resetter currentmillis til previousmillis ();
// play track 1. name on sd-card: 001.mp3
Serial.print("t");
Serial.write(1);
//delay(1000);
//Serial.println(sensorReading[i]); //threshold-println
Basically, i've connected 6 piezo sensors to the arduino.
I've ordered this device: Flexible speaker
And i've put it up to a mp3 trigger.
The idea is, that i need to randomize the different mp3 samples, when the if() method's are called upon the code - which is when the threshold from the piezo's are between 50 and 150.
I've found the
randNumber = random(300);
Serial.println(randNumber);
Function to be built in, but i can't seem to see how it's supposed to randomly trigger the mp3 files?
