Multiple serial devices , ESP8266 & E32 LoRa on Pro Mini
I am trying to code a Pro Mini to handle two serial devices. It is intended to receive data via a ebyte E32 Lora module and transfer to the internet via WiFi using a ESP8266 module. Both devices are working correctly separately using Rx/Tx but the difficulty comes in running them together. I am using Software serial to set up two different serial ports, each on seperate I/o pins. I tried using *begin commands for each software serial channel but it appears only the last one started runs.
Any idea why?
Thanks
Donall
Help us help you.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Please post a schematic.
Please post an image of your project.
Please describe the problem better then you just did.
any particular reason to use a pro mini when you have a ESP8266 module?
why not connect the E32 Lora module directly to the ESP8266 ?
the softwareserial documentation states
It cannot transmit and receive data at the same time.
If using multiple software serial ports, only one can receive data at a time.
could these cause your problems?
