multipleDS18B20 + TimeSerialDateStrings
Hi
My project is to monitor two temperatures and plot them vs time.
Separately, my two DS18B20 work well and the TimeSerialSateStrings give me what I want.
When I "mix" the codes to generate a single sketch, my two sensors don't answer anymore to temperature change - even if the temperatures and time are reported on my txt file and there is no error message.
Apparently the sensors are not "read" and the arduino reports temperatures stored in its memory.
I attached to this message the code mixed.
Could anyone help me on that?
Thank you very much:-/
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Time.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 9
#define TIME_HEADER  "T"   // Header tag for serial time sync message
#define TIME_REQUEST  7    // ASCII bell character requests a time sync message
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device addresses
DeviceAddress insideThermometer, outsideThermometer;
void setup(void)
  // start serial port
  Serial.println("Dallas Temperature IC Control Library Demo");
  // Start up the library
  sensors.begin();
  // locate devices on the bus
  Serial.print("Locating devices...");
  Serial.print("Found ");
  Serial.print(sensors.getDeviceCount(), DEC);
  Serial.println(" devices.");
  // report parasite power requirements
  Serial.print("Parasite power is: ");
  if (sensors.isParasitePowerMode()) Serial.println("ON");
  else Serial.println("OFF");
  if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
  if (!sensors.getAddress(outsideThermometer, 1)) Serial.println("Unable to find address for Device 1");
  Serial.print("Device 0 Address: ");
  printAddress(insideThermometer);
  Serial.print("Device 1 Address: ");
  printAddress(outsideThermometer);
  // set the resolution to 9 bit
  sensors.setResolution(insideThermometer, TEMPERATURE_PRECISION);
  sensors.setResolution(outsideThermometer, TEMPERATURE_PRECISION);
  Serial.print("Device 0 Resolution: ");
  Serial.print(sensors.getResolution(insideThermometer), DEC);
  Serial.print("Device 1 Resolution: ");
  Serial.print(sensors.getResolution(outsideThermometer), DEC);
  Serial.println("Temp C: ");
   // TimeSerial.pde
  pinMode(13, OUTPUT);
  setSyncProvider( requestSync);  //set function to call when sync required
  Serial.println("Waiting for sync message");
void loop(void)
   // TimeSerial.pde
  if (Serial.available())
    processSyncMessage();
  if (timeStatus()!= timeNotSet)
    digitalClockDisplay();
  if (timeStatus() == timeSet)
    digitalWrite(13, LOW); // LED on if synced
    digitalWrite(13, HIGH);  // LED off if needs refresh
  printData(insideThermometer);
  printData(outsideThermometer);
// function to print a device address
void printAddress(DeviceAddress deviceAddress)
  for (uint8_t i = 0; i < 8; i++)
    // zero pad the address if necessary
    if (deviceAddress[i] < 16) Serial.print("0");
    Serial.print(deviceAddress[i], HEX);
// function to print the temperature for a device
void printTemperature(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
 // Serial.print("Temp C: ");
  Serial.print(tempC);
// function to print a device's resolution
void printResolution(DeviceAddress deviceAddress)
  Serial.print("Resolution: ");
  Serial.print(sensors.getResolution(deviceAddress));
// main function to print information about a device
void printData(DeviceAddress deviceAddress)
 // Serial.print("Device Address: ");
 // printAddress(deviceAddress);
  Serial.print(" ");
  printTemperature(deviceAddress);
  Serial.print(" ");
void digitalClockDisplay(){
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
void processSyncMessage() {
  unsigned long pctime;
  const unsigned long DEFAULT_TIME = 1357041600; // Jan 1 2013
  if(Serial.find(TIME_HEADER)) {
     pctime = Serial.parseInt();
     if( pctime >= DEFAULT_TIME) { // check the integer is a valid time (greater than Jan 1 2013)
       setTime(pctime); // Sync Arduino clock to the time received on the serial port
time_t requestSync() {
  Serial.write(TIME_REQUEST);
  return 0; // the time will be sent later in response to serial mesg
DS18B20_2sensors_TimeSerial_ino.ino (4.48 KB)
It is better that you attach the code using the hatch icon so that it can be sensibly read in this window.
Here is some code doing much the same thing.
//  This Arduino sketch reads DS18B20 "1-Wire" digital
//  temperature sensors.
//  http://www.hacktronics.com/Tutorials/arduino-1-wire-tutorial.html
//  Serial print commands are for PLX-DAQ
 size 22 894
#include <SPI.h>
#include <PCD8544.h>             // Nokia 5110
#include <SD.h>                  // SD card
#include <string.h>              // from Date As Filename
#include "RTClib.h"              // from Date As Filename
#include "Wire.h"                // MUST HAVE lib for LCD disp, SD card, and serial
#define DS1307_ADDRESS 0x68
RTC_DS1307 RTC;
static PCD8544 lcd;
File myFile;
char filename[] = "00000000.CSV";
// Custom symbols
static const byte DEGREES_CHAR = 1;
static const byte degrees_glyph[] = { 0x00, 0x07, 0x05, 0x07, 0x00 };
static const byte SLASH_CHAR = 2;
static const byte slash_glyph[] = {0x00,0x20,0x10,0x08};
// Yellow group Lismore
byte InThermo[8] =  {
  0x28, 0x39, 0xFD, 0x50, 0x04, 0x00, 0x00, 0X69};
byte OutThermo[8] = {
  0x28, 0x09, 0xA9, 0xC0, 0x03, 0x00, 0x00, 0x95};
byte DrainThermo[8] = {
  0x28, 0x62, 0xA5, 0x2D, 0x04, 0x00, 0x00, 0x21};
#define ONE_WIRE_BUS 3
int  second, minute, hour, weekDay, monthDay, month, year;
int k=0;
const int chipSelect = 4;
float InTemp, OutTemp, DrainTemp, diff;
// Define the strings for our datastream IDs
char sensorId0[] = "InThermo";
char sensorId1[] = "OutThermo";
char sensorId2[] = "DrainThermo";
char calcId1[] = "diff";
   lcd.begin(84, 48);
     // Register the custom symbols...
  lcd.createChar(DEGREES_CHAR, degrees_glyph);
  lcd.createChar(SLASH_CHAR, slash_glyph);
  Wire.begin();
  delay(300);//Wait for newly restarted system to stabilize
  lcd.setCursor (0,0);
  lcd.print("Initializing");
  delay(2000);
  lcd.setCursor (0,1);
  pinMode(53, OUTPUT);
 if (!SD.begin(chipSelect))
    lcd.print("failed!");
    delay (2000);
    return;
  lcd.println("init. OK!");
  delay(2000);
      getFileName();
      lcd.println(filename);
        delay(2000);
  lcd.clear();
// First serial output "LABEL" is an Excel command, printed on reset
  Serial.println("LABEL,Time,InTemp,OutTemp,diff,DrainTemp");
  sensors.setResolution(InThermo, 12);
  sensors.setResolution(OutThermo, 12);
  sensors.setResolution(DrainThermo, 12);
    running();
  GetClock();
  if (hour == 0 && minute == 0 && second <2)
    getFileName();
  //get the values from the DS8B20's
  sensors.requestTemperatures();
  InTemp = (sensorValue(InThermo));
  OutTemp = (sensorValue(OutThermo));
  DrainTemp = (sensorValue(DrainThermo));
  diff = OutTemp - InTemp;
 Serial.print("DATA,TIME,");  // Excel commands
  Serial.print(InTemp);
  Serial.print(" ,  ");
  Serial.print(OutTemp);
  Serial.print(diff);
  Serial.println(DrainTemp);
  lcd.setCursor(49,0);
  lcd.print(InTemp);
  lcd.setCursor(49,1);
  lcd.print (OutTemp);
  lcd.setCursor(49,2);
  lcd.print(DrainTemp);
  lcd.setCursor(49,3);
  lcd.print(diff);
  k=k+1;
  if (k>9 )
  myFile = SD.open(filename, FILE_WRITE);//<<<<<<<<<<<<< OPEN
  myFile.print(hour);
  myFile.print(":");
  myFile.print(minute);
  myFile.print(":");
  myFile.print(second);
  myFile.print(",");
  myFile.print(InTemp);
  myFile.print(",");
  myFile.print(OutTemp);
  myFile.print(",");
  myFile.print(DrainTemp);
  myFile.print(",");
  myFile.println();
       myFile.close();//>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>CLOSE
      k=0;
  delay(850);
}  // loop ends here
//sensorValue function
float sensorValue (byte deviceAddress[])
  float tempC = sensors.getTempC (deviceAddress);
  return tempC;
byte bcdToDec(byte val)  {
  // Convert binary coded decimal to normal decimal numbers
  return ( (val/16*10) + (val%16) );
void GetClock(){
  // Reset the register pointer
  Wire.beginTransmission(DS1307_ADDRESS);
  byte zero = 0x00;
  Wire.write(zero);
  Wire.endTransmission();
  Wire.requestFrom(DS1307_ADDRESS, 7);
  second = bcdToDec(Wire.read());
  minute = bcdToDec(Wire.read());
  hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
  weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
  monthDay = bcdToDec(Wire.read());
  month = bcdToDec(Wire.read());
  year = bcdToDec(Wire.read());
void getFileName(){
  DateTime now = RTC.now();
  filename[0] = (now.year()/1000)%10 + '0'; //To get 1st digit from year()
  filename[1] = (now.year()/100)%10 + '0'; //To get 2nd digit from year()
  filename[2] = (now.year()/10)%10 + '0'; //To get 3rd digit from year()
  filename[3] = now.year()%10 + '0'; //To get 4th digit from year()
  filename[4] = now.month()/10 + '0'; //To get 1st digit from month()
  filename[5] = now.month()%10 + '0'; //To get 2nd digit from month()
  filename[6] = now.day()/10 + '0'; //To get 1st digit from day()
  filename[7] = now.day()%10 + '0'; //To get 2nd digit from day()
void running(){
  lcd.setCursor(0,0);
  lcd.print("In");
  lcd.setCursor(31,0);
  lcd.print("\001C ");
  lcd.setCursor(0,1);
  lcd.print("Out");
  lcd.setCursor(31,1);
  lcd.setCursor(0,2);
  lcd.print("Drain");
  lcd.setCursor(31,2);
  lcd.setCursor(0,3);
  lcd.print("diff");
  lcd.setCursor(31,3);
