Hey guys, I've been trying to use mux 74HC4067 to verify voltage divider rule. But for some reason My A0 pin is never activated causing the whole program to show a Row's of 0's in Virtual terminal. I followed the link below
The code and proteus diagram is given and i recreated it but the only change i made was instead of using Variable resistor i used normal resistor. But i doubt that would cause any problem as all my digital pins are activated in arduino but A0 is not lighting up so i think it's inactive all the time.
Here is my circuit and code below:
#define analogPin0
int s0 = 5;
int s1 = 6;
int s2 = 7;
int s3 = 8;
// Atur pin select sebagai output
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
/* CD74HC4067 Module Analog Multiplexer 16-Ch Analog Digital 74HC4067
Ubah-ubahlah nilai S0, S1, S2, dan S3 untuk memilih input mana yang digunakan berdasarkan tabel berikut:
S0 S1 S2 S3 y ke-
0 0 0 0 0
1 0 0 0 1
0 1 0 0 2
1 1 0 0 3
0 0 1 0 4
1 0 1 0 5
0 1 1 0 6
1 1 1 0 7
0 0 0 1 8
1 0 0 1 9
0 1 0 1 10
1 1 0 1 11
0 0 1 1 12
1 0 1 1 13
0 1 1 1 14
1 1 1 1 15
Catatan: 0 berarti LOW dan 1 berarti HIGH pada Arduino
// Pilih y0 sebagai input
digitalWrite(s0, LOW); //0 0 0 0 0
digitalWrite(s1, LOW);
digitalWrite(s2, LOW);
digitalWrite(s3, LOW);
int sensorValue1 = analogRead(A0);
float voltage1 = sensorValue1 * (5.0 /1023.0);
delayMicroseconds(200);
// Pilih y1 sebagai input
digitalWrite(s0, HIGH); //1 0 0 0 1
int sensorValue2 = analogRead(A0);
float voltage2 = sensorValue2 * (5.0 /1023.0);
// Pilih y2 sebagai input
digitalWrite(s0, LOW); //0 1 0 0 2
digitalWrite(s1, HIGH);
int sensorValue3 = analogRead(A0);
float voltage3 = sensorValue3 * (5.0 /1023.0);
// Pilih y3 sebagai input
digitalWrite(s0, HIGH);//1 1 0 0 3
int sensorValue4 = analogRead(A0);
float voltage4 = sensorValue4 * (5.0 /1023.0);
// Pilih y4 sebagai input
digitalWrite(s0, LOW);//0 0 1 0 4
digitalWrite(s2, HIGH);
int sensorValue5 = analogRead(A0);
float voltage5 = sensorValue5 * (5.0 /1023.0);
// Pilih y5 sebagai input
digitalWrite(s0, HIGH);//1 0 1 0 5
int sensorValue6 = analogRead(A0);
float voltage6 = sensorValue6 * (5.0 /1023.0);
// Pilih y6 sebagai input
digitalWrite(s0, LOW);//0 1 1 0 6
int sensorValue7 = analogRead(A0);
float voltage7 = sensorValue7 * (5.0 /1023.0);
// Pilih y7 sebagai input
digitalWrite(s0, HIGH);//1 1 1 0 7
int sensorValue8 = analogRead(A0);
float voltage8 = sensorValue8 * (5.0 /1023.0);
// Pilih y8 sebagai input
digitalWrite(s0, LOW);//0 0 0 1 8
digitalWrite(s3, HIGH);
int sensorValue9 = analogRead(A0);
float voltage9 = sensorValue9 * (5.0 /1023.0);
// Pilih y9 sebagai input
digitalWrite(s0, HIGH);//1 0 0 1 9
int sensorValue10 = analogRead(A0);
float voltage10 = sensorValue10 * (5.0 /1023.0);
// Pilih y10 sebagai input
digitalWrite(s0, LOW);//0 1 0 1 10
int sensorValue11 = analogRead(A0);
float voltage11 = sensorValue11 * (5.0 /1023.0);
// Pilih y11 sebagai input
digitalWrite(s0, HIGH);//1 1 0 1 11
int sensorValue12 = analogRead(A0);
float voltage12 = sensorValue12 * (5.0 /1023.0);
// Pilih y12 sebagai input
digitalWrite(s0, LOW);//0 0 1 1 12
int sensorValue13 = analogRead(A0);
float voltage13 = sensorValue13 * (5.0 /1023.0);
// Pilih y13 sebagai input
digitalWrite(s0, HIGH);//1 0 1 1 13
int sensorValue14 = analogRead(A0);
float voltage14 = sensorValue14 * (5.0 /1023.0);
// Pilih y14 sebagai input
digitalWrite(s0, LOW);//0 1 1 1 14
int sensorValue15 = analogRead(A0);
float voltage15 = sensorValue15 * (5.0 /1023.0);
// Pilih y15 sebagai input
digitalWrite(s0, HIGH);//1 1 1 1 15
int sensorValue16 = analogRead(A0);
float voltage16 = sensorValue16 * (5.0 /1023.0);
Serial.print(voltage1);
Serial.print(" ");
Serial.print(voltage2);
Serial.print(" ");
Serial.print(voltage3);
Serial.print(" ");
Serial.print(voltage4);
Serial.print(" ");
Serial.print(voltage5);
Serial.print(" ");
Serial.print(voltage6);
Serial.print(" ");
Serial.print(voltage7);
Serial.print(" ");
Serial.print(voltage8);
Serial.print(" ");
Serial.print(voltage9);
Serial.print(" ");
Serial.print(voltage10);
Serial.print(" ");
Serial.print(voltage11);
Serial.print(" ");
Serial.print(voltage12);
Serial.print(" ");
Serial.print(voltage13);
Serial.print(" ");
Serial.print(voltage14);
Serial.print(" ");
Serial.print(voltage15);
Serial.print(" ");
Serial.println(voltage16);
