Multiplexing the same i2c devices
Hello, i am making a solar tracker with 4 TSL45315 light sensor, so my problem is the I2C bus, reading on the web I found the answer to be multiplexing the I2C bus (TCA9548A multiplexor), the problem now is i cant seem to read any of the ports on the multiplexer. I am able to read a single sensor but when i try to read a single sensor through a port on the multiplexer it just cant be read.
this is the main document i was using as a guide
Can anyone help? Thank you
Bare sensor chips, or chips on breakout boards?
What are the pull up resistor values?
How long is the wiring?
Leo..
Welcome to the forum.
Any reason why you have gone to I2C bus for light sensor when a simple LDR or photo transistor will do the job?
What model Arduino are you using?
Tom.... :slight_smile:
